where is this oil coming from??!!
Old Apr 2, 2011 | 01:27 PM
foxracing4500's Avatar
Question where is this oil coming from??!!
deleted
Old Apr 2, 2011 | 02:56 PM
ImTheDevil's Avatar
Probably from the CHRA of the turbo - shaft seal leaks arent uncommon, especially with higher mileage on a stock, original turbo.
Old Apr 2, 2011 | 03:25 PM
deleted
Old Apr 2, 2011 | 04:29 PM
MilitantGrunt's Avatar
It is normal.
Though the PCV valve that sits in your inlet tube may be getting gunked up, I suggest you change that, along with any other broken pieces of PCV. These cars use a blow by system, there will always be oil in the intake tract. From your photos you have a relatively normal amount of oil in there.
If your CHRA was going bad you'd have significantly higher amounts of oil than that.
Old Apr 2, 2011 | 04:36 PM
deleted
Old Apr 2, 2011 | 05:19 PM
mikekey's Avatar
yup, it's normal. Saw your PM, clean everything and it will build back up after a year. But it's definitely a lot worse looking if it's never been cleaned up or replaced.
Old Apr 2, 2011 | 05:36 PM
bradtyler02's Avatar
Originally Posted by foxracing4500
But where is this oil coming from
Well, millions of years ago, some **** died, got trapped in some ****, turning into some sort of ****. Millions of years later, some dudes dug the **** up with some digging ****, processed the **** with some ****, and put the **** in a plastic bottle. Then, you bought the **** and added it to your engine, where some shitty seal took a **** and leaked the **** inside the engine to where it it now...
Ain't that some ****?
Old Apr 6, 2011 | 07:56 PM
cruzer555's Avatar
Hahaha that made me lol... Also your profile pic is from one of my favorite commercials
Sheasta
Oct 25, 2012 01:27 PM
2KB5
Sep 13, 2011 01:04 PM
chefboyarde
Nov 11, 2008 11:57 PM
darkminotaur
Jan 3, 2008 11:51 AM
Deleted User
Feb 11, 2004 03:15 PM
