about to change my thermostat and..
i saw that you need to take the negative post on the battery off. i tried searching around a little bit.. but what would be the engine code i need to do this...kinda of a newbie.. and how would i enter it?
thanks
thanks
What?
Just hope under the car, remove the 13mm bolt holding the snub brace on, remove the two 10mm bolts holding the t-stat housing in, pop out the old t-stat and o ring, put the new one in, and put it all back together. It's no big deal.
since the DIY in the audidiy web site is waaayyy more complicated then that.
I have an Audi 1999.5 1.8t..
Thanks for your help in advance!!
Crawl under your car and try to remove the t-stat housing bolts. There will be a bracket blocking you from getting to one of them, that's the snub brace. You'll want to drain your coolant first too, actually.
Could you link me to the thermostat replacement DIY?
