ABS and Brake light randomly goes on
Old Jun 21, 2008 | 07:00 PM
gamebrigada's Avatar
Default ABS and Brake light randomly goes on
I recently changed my rear brake pads because they were worn out, Everything went fine for a few days, but then the Brake Light goes on and ABS light flashes. Sometimes it turns on right when you start the car, but other times it turns on randomly. Ive looked at error codes with Vag-Com, and it says the problem is with the connection to the ABS module or something of that sort. Where is the ABSmodule located, and how would I go at getting to it?
What else may be the problem?
I bought my Audi from an auction, it was damaged, but not too bad, the whole rear was pretty messed up, including the lift gate, bumper, and a little bit of the frame. I got everything fixed and replaced, but may that be a factor of the problem? I love the car and all but this light is really getting to me, I garaged up my car just in case its bad to drive with the problem.
Old Jun 21, 2008 | 07:04 PM
hiwords's Avatar
Default RE: ABS and Brake light randomly goes on
module should be under the rear seat. the rear hub has an abd sensor on it, vag com should have been able to pick up which sensor it is if it was the sensor. get a screen shot and post it
Old Jun 22, 2008 | 12:05 AM
S_R_N83's Avatar
The car isn't going to bebad to drive, you just wont have ABS at the moment. My best guess, is that you either gotan ABSsensor dirty, damaged it,or didn't connect it all the way when you were changing the back pads.
If its the actual ABS Module under the hood, then you can either get a new one for a lot of money from Audi, or get it rebuilt for a lot less. Search and you will find a lot of info. on that.
Old Jun 22, 2008 | 06:26 AM
techbod's Avatar
what was the fault code?
Old Jun 22, 2008 | 09:39 AM
CRAZYHAWK's Avatar
ABS module is near the power steering reservoir.
Old Jun 22, 2008 | 09:54 AM
steezybme's Avatar
if you dont fix the problem kind like i didnt on mine it will stay on, and your abs moduler will go bad and its alot of money to replace...
Old Jun 23, 2008 | 01:17 AM
fritz's Avatar
try reseating the abs sensor and make sure its allll the way pushed in.
Old Jun 26, 2008 | 05:31 PM
Heres the ABS code
VAG-COM Version: Release 311.2-N
Control Module Part Number: 8E0 614 111 M
Component and/or Version: ABS/EDS 5.3 QUATTRO D31
Software Coding: 0273004134
Work Shop Code: BB 24302
1 Fault Found:
01203 - Electrical Connection between ABS and Instrument Cluster
03-10 - No Signal - Intermittent
I have taken off both rear wheels to check the sensor, and it seems that I shouldn't have done anything to it since it is in the front of the brake disk, unlike the pads which are on the back, so I don't think I did anything to them.
Also My engine light has gone on, and my VAG-COM has gone weird, saying that I need to login and whatnot, but gives me the codes anyway. Any help on these is very appreciated
Control Module Part Number: 4D0 907 551 AH
Component and/or Version: 2.8L V6/5V MOTR AT D01
Software Coding: 06251
Work Shop Code: WSC 06325
6 Faults Found:
18010 - Power Supply Terminal 30: Voltage too Low
P1602 - 35-10 - - - Intermittent
16684 - Shareware Version. To Decode all DTCs
P0300 - 35-10 - Please Register/Activate - Intermittent
16686 - Shareware Version. To Decode all DTCs
P0302 - 35-10 - Please Register/Activate - Intermittent
18014 - Shareware Version. To Decode all DTCs
P1606 - 35-00 - Please Register/Activate
Old Jun 26, 2008 | 06:17 PM
Well I found a table of errors, and the last code on the engine has to do with the problem.
18014 P1606 Rough Road Spec Engine Torque ABS-ECU Electrical Malfunction
Any ideas?
chaseacheek
Dec 23, 2013 01:07 PM
wallbanger33
Nov 21, 2013 06:23 PM
akm0228
Jul 2, 2012 10:13 AM
Hayes
Oct 17, 2009 11:42 AM
