ABS Light on at random times
Hello all,
Everytime I go on the interstate and am above 80mph for a long period of time my abs light turns on.... but if i turn my car off and turn it back on it goes away. any suggestions?
In my experience this was the result of an ABS sensor that wasn't pushed in far enough, or was damaged. Could also be an ABS module in need of a rebuild.
Only way to know is to check the ABS module for error codes with VAG-COM.
If the module is bad he should see the ABS light flashing much more often or always. The ABS related codes don't get stored, I had the same problem and I was not able to fix it until I made a scan before turning the car off.
I know it's totally off-topic but Eastern Europe is pretty warm this time of the year, the temperature is around 80 now and can go up to 95 - 100 in mid August. Where exactly would you like to go and what do you want to see exactly?
hyroglyfiks
B7 Models
Feb 2, 2014 02:46 PM
ianwhite101
Jul 30, 2006 02:42 PM
