ABS Light on at random times
Old May 30, 2011 | 07:51 PM
patrixx006's Avatar
Default ABS Light on at random times
Hello all,
Everytime I go on the interstate and am above 80mph for a long period of time my abs light turns on.... but if i turn my car off and turn it back on it goes away. any suggestions?
Old May 30, 2011 | 07:52 PM
patrixx006's Avatar
also its a 2001 a4 1.8tqm
Old May 30, 2011 | 08:08 PM
MetalMan's Avatar
In my experience this was the result of an ABS sensor that wasn't pushed in far enough, or was damaged. Could also be an ABS module in need of a rebuild.
Only way to know is to check the ABS module for error codes with VAG-COM.
Old May 30, 2011 | 09:23 PM
Audisaurus's Avatar
SHould just be a sensor
Old May 31, 2011 | 01:16 AM
Cristisor's Avatar
+1 for just a sensor but you'll have to do a scan for codes when the light is flashing in order to know which sensor is the faulty one
Old May 31, 2011 | 09:16 AM
Audisaurus's Avatar
The codes should be stored right? shouldnt have to wait for the light, Idk if its different for the ABS, i know if your module is bad you cant get past the fault codes to get any other codes.
Old May 31, 2011 | 10:42 AM
Cristisor's Avatar
If the module is bad he should see the ABS light flashing much more often or always. The ABS related codes don't get stored, I had the same problem and I was not able to fix it until I made a scan before turning the car off.
Old May 31, 2011 | 11:06 AM
Audisaurus's Avatar
hows romaina this time of year? i am planning a trip over seas
Old Jun 1, 2011 | 01:30 AM
Cristisor's Avatar
I know it's totally off-topic but Eastern Europe is pretty warm this time of the year, the temperature is around 80 now and can go up to 95 - 100 in mid August. Where exactly would you like to go and what do you want to see exactly?
skyhighhobby
Feb 17, 2014 12:18 AM
hyroglyfiks
B7 Models
Feb 2, 2014 02:46 PM
A4 2000
Dec 30, 2011 12:33 AM
MartinCieslak1
Feb 7, 2010 05:50 PM
ianwhite101
Jul 30, 2006 02:42 PM
