ABS misc questions and help 99 2.5TDI(inspection issue)
Old Jan 19, 2012 | 01:24 PM
AudiInfantry's Avatar
it was a red diagnostic tool, with a VAG connector. the computer said to use an S-7 key, but all he had was a K-7 key, it worked anyway though. it showed wheel speed in neutral, and no wheel speed in 1st. can't remember where i found it, it was under other tests i think.. checked boost pressure, MAP, MAF, fuel injection rates, cylinder fire, all sorts of good stuff.
Well i'm not sure really, i was going off what the mechanic on duty there said. he said 2.5, perhaps he mean 2.5Ω, but he said something about testing the sensor plug using a paper clip to test the connection.
really its all coming to the same place, just leaving out resistance. say, If a circuit has 10 Volts applied, with a 20Ω load, that would be 0.5Amps, so i wasn't really wrong is saying voltage and amps, just left out resistance.
So either way, the connection is at fault with the connector somewhere.
billycolorado
Jun 30, 2020 08:34 AM
knyks342
Jul 21, 2011 07:21 PM
knyks342
Feb 24, 2011 04:47 PM
Asianicestyles
Jun 1, 2008 05:22 AM
BornToRun
Oct 16, 2006 10:28 PM
