misfire question
Old Jan 19, 2012 | 08:53 AM
murdox's Avatar
Default misfire question
First - stuttering under hard acceleration accompanied by a flashing CEL is a misfire correct?
Second: I guess ill replace the coilpacks. Should I replace the plugs as well? I currently have BKE6E ( i think ) gapped to .32. The car is chipped.
Which plugs should i be using?
Also, i'm going to call Audi to see if i fall under the recall
Old Jan 19, 2012 | 01:12 PM
mobitsfa's Avatar
.032 is stock. You should gap them to .028 if you're chipped.
Vag or just scan your ecu first to see which cylinder(s) are misfiring.
Old Jan 19, 2012 | 01:55 PM
MetalMan's Avatar
Many people would also recommend going with a plug one heat range colder when getting chipped as well (BKR6E is the normal heat range). When I chipped my car I ran BKR7E plugs with 0.028" gap.
Old Jan 19, 2012 | 02:42 PM
murdox's Avatar
thanks guys...
called audi - my VIN is under that recall - i'm pretty sure they are going to replace the coils for me -for free!
whooopiee
Ill change the plugs once i get it back - BKE7 gapped to .28
thanks for the input
Old Jan 19, 2012 | 04:59 PM
MetalMan's Avatar
Just to make sure, the plugs are NGK BKR7E, so you don't order the wrong ones.
Home Page > Search > Bkr7e > ES#8924 Spark Plugs - Set Of Four (#BKR7E) - BKR7EKT-4CYL
Bligh
Dec 13, 2010 08:56 PM
rabenson92
Aug 2, 2010 12:06 PM
Colin1
Feb 14, 2010 01:13 PM
Heber
Jan 13, 2010 03:16 PM
zoidberg3.0
Apr 1, 2009 06:47 PM
