ABS problem! help?
Old Aug 18, 2010 | 07:23 PM
Pedja's Avatar
Default ABS problem! help?
i was just driving normally this time, lol, and stopping nice and slow when my abs started, at first i thought i was just thinking it up, but then now on every gentle stop it turns on right before i come to a complete stop.
no lights are on the dash about abs just it kicks in randomly when im about to stop
anyone have/had a similar problem? what should i do, any advice?
thanks.
Old Aug 18, 2010 | 10:40 PM
markymarc's Avatar
I have/had the same issue...your ABS light won't come on, but you WILL have a code, basically, I'm assuming you are going under 20mph WHEN this happens correct?
What's happening is, one tire is telling the computer that it's not matching up to the same speed as the others during slow speeds....it could be a bad tooth on the ABS sensor ring on the axle, could also be a bad ABS sensor itself, etc...figuring out which one it is, could be a big pain in the a.....
Old Aug 19, 2010 | 11:31 AM
Pedja's Avatar
ahhhhh crap.... i heard the sensors can be pretty expensive but then again i could get lucky by cleaning the sensor from rust? or something like that? DAMN IT!
Old Aug 19, 2010 | 02:15 PM
Pedja's Avatar
fak it... i pulled the fuse on the abs, got a light show on the console now but its not rumbling when i stop atleast, ill keep it like this until i get enough cash for a new sensor. any idea how much for a sensor?
Old Aug 19, 2010 | 05:31 PM
TeeterTawter's Avatar
It may not be a sensor, my buddy replaced all 4 sensors, had his abs module rebuilt, and is still having this issue. I told him to inspect the rings on the axle but of course he never listens to me.
Old Aug 19, 2010 | 05:47 PM
a4vt1.8t's Avatar
I was looking on napa the other day, I think it was like 150 a sensor
Old Aug 19, 2010 | 05:48 PM
your in ontario, contact neil at owasco in whitby. pm me for details. He can get you some deals on oem parts
Old Aug 19, 2010 | 08:36 PM
markymarc's Avatar
you can get aftermarket sensors on ebay, I've tried them and they work pretty good. I found my problem by accident. I had a rear sensor ABS light and code on the right rear...I had replaced the left rear axle earlier....but NOT the right rear.....turns out, the right rear sensor ring on the axle iteself was MORE WORN than the NEW one, duh, of course, so that caused the speed discrepancy....
Old Aug 20, 2010 | 11:21 AM
MetalMan's Avatar
If you have VAG-COM you can find out exactly which wheel is the problem. All you have to do is access the ABS module, and open up the dialog for Measuring Blocks (I think it's called). From there you can have it display ABS speed sensing for each wheel while you're driving.
Old Aug 20, 2010 | 01:02 PM
Pedja's Avatar
alright i shall do that! thanks alot!
Christopher Nemitz
Mar 12, 2012 09:02 PM
jimc137
Mar 9, 2011 06:48 PM
spyrosg7
Apr 4, 2010 07:48 PM
RIA6
Nov 30, 2006 09:06 PM
