ABS problems
Old Jan 12, 2009 | 11:59 PM
The Bishop's Avatar
And if that doesn't work, then Modulemaster.com is your friend.
They are my friends now.
Old Jan 13, 2009 | 12:40 PM
brrman's Avatar
Hooking to a VAG should indeed tell you which corner is bad. It will be obvious which sensor has the wrong/deviated return values.
Old Jan 13, 2009 | 02:14 PM
onepoint8tee's Avatar
Any idea what blocks in vag to be looking at for that? I was never able to find them when I was trying to diagnose mine.
Old Jan 13, 2009 | 02:39 PM
CCA4's Avatar
Did you try block 03?
Old Jan 13, 2009 | 05:08 PM
Dallas09's Avatar
If you check measuring blocks on VAG it will show individual wheel speeds. The one that is different from the rest is the culprit. I would think that if you repeatedly press the brakes when coming to a stop, the ABS light should eventually come on and throw a code, it doesnt know theres a problem immedietly until it sees the same wheel sensor constantly showing a different wheel speed.
When i did my front end i didnt push the wheel speed sensor in far enough so i did whats above to diagnose which side it was.
Smokin Tubes
Feb 5, 2012 10:11 AM
mykien23
Dec 2, 2011 08:55 AM
redrhino
Oct 26, 2011 03:49 PM
commedecargons
Nov 9, 2005 06:43 PM
SamJamaica
Jun 13, 2005 02:07 AM
