ABS Sensor
Old Jun 9, 2010 | 06:46 PM
AudimaniaA4's Avatar
Default ABS Sensor
One of my ABS sensors is broken. I am curious if anyone here can provide me with instructions on how I can replace it. It's not the ABS module but the sensor on the wheel that is broken.
Old Jun 9, 2010 | 09:56 PM
kevace1's Avatar
you just have to remove the wheel from the corresponding location and just pop out the sensor, it wil be located right outside where the wheel bearing is. then you will have to fich the wires out and do the same for the replacement. I know this applies to the front as I have changed my front right one about 2 months ago, and the b5 vw passats use the same exact sensor btw, just that one has a audi logo, the other has vw logo woopudydoodadi.......
Old Jun 10, 2010 | 03:09 AM
StormUnite's Avatar
the vw logo prolly lowers the price to lol
Old Jun 10, 2010 | 03:30 AM
Dallas09's Avatar
They can be hard to remove, they are usually frozen in there. The easiest way to remove them is to pull the wheel carrier out so you can tap them out instead of try to pull them out.. That can be alot of work though, it might just take some work to get them out. Trace the wire up to the rubber grommet, and pull out the rubber grommet to get to the connector. If it is a rear sensor, you remove the rear seat (simply pull up on it) and disconnect it there and feed the wire through.
Old Jun 10, 2010 | 04:40 PM
Thanks a bunch. Does any one know a good place on line where I can purchase the parts?
Old Jun 11, 2010 | 08:54 AM
paintballpimp765's Avatar
i believe the rear sensors are the same too just longer cables. i would go with ebay or a junk yard because new they can get up to 150$
Old Jun 11, 2010 | 10:36 AM
lajos's Avatar
I purchased an ABS sensor at my local AutoZone. It was a special order.
I second the opinion above that it's hard to remove because of rust. I could not get the old sensor in one piece. Before installing the new sensor I cleaned out the hole and applied anti seize.
neomaxddr
Apr 1, 2009 03:16 AM
