AC Compressor Wire broke
Old Jun 1, 2009 | 12:42 PM
briguy3770's Avatar
Unhappy AC Compressor Wire broke
So the ac was blowing warm air and i figured i needed a recharge. When i took it to the shop they said the electrical wire to it had been severed. My question is can i re attach the wire? If not, how difficult of a job is this to do myself because parts and labor is going to cost a fortune. any advice is appreciated.
Old Jun 1, 2009 | 03:43 PM
Tweaked's Avatar
The wire to the clutch or to the connector on the compressor?
Old Jun 1, 2009 | 03:51 PM
ghost6303's Avatar
splice it just like any other wire. if it is sheared off at the connector that might be more difficult.
Old Jun 3, 2009 | 12:05 AM
briguy3770's Avatar
clutch i believe..i think i can splice the wire back though. is there anything i should be aware of?
Old Jun 3, 2009 | 02:09 AM
Tweaked's Avatar
That totally depends on where it's broken. If it's broken in the coil, you're kinda screwed. If it's done incorrectly, you might keep blowing the A/C fuse. Or, if the coil is shorted, it will keep burning out the wire and the fuse, in which case, you need a compressor anyway.
Just out of curiosity, did you check the fuse for the compressor? While you're at it, check the resistance of the compressor clutch coil.
Nevalite
May 9, 2010 10:54 AM
killacam561
Jun 1, 2008 11:51 PM
edrocks3
Mar 7, 2008 09:41 AM
tristanlee85
Sep 10, 2006 06:08 AM
ivo
Aug 27, 2006 01:47 AM
