ac and engine temp running weird
Old Jul 13, 2009 | 07:30 PM
ast03's Avatar
Default ac and engine temp running weird
my 2001 1.8 ac doesnt blow cold air when im not moving, like at a stop light or just turning on the car. when i turn my car on the air will b hot and the rpms start to bounce up and down... but, the rpms only bounce like this wen the air is on... if the ac is off the rpms are normal... it takes about 5-10 minutes of straight driving for the cold air to start to kick in... once its working it blows very cold air.. but if i stop at a stop light the rpms start to bounce up and down and the ac will blow warm air and sometimes stop blowing any air for about 5 seconds and then start blowing warm again.. i noticed while i was driving and hitting every stop light that my engine temp gauge was goin from the middle, which it normally were its at, to all the way to the left very rapidly, stay there for 30 seconds then go back to normal.. this seems to happen as the ac is acting weird..
any advice would be appreciated.. thx
Old Jul 13, 2009 | 09:45 PM
ghost6303's Avatar
change your coolant temp sensor now. its $10-20 at any auto parts store or audi dealer.
verify that the secondary fan turns on when the engine is up to temp and the a/c is on.
Old Jul 13, 2009 | 10:49 PM
ImTheDevil's Avatar
Agreed 100%.
Old Jul 14, 2009 | 12:19 AM
ast03's Avatar
cool.. is this something that i can do on my own or do i need to take it in and have changed... i dont know where that is on the car or anything. and for the secondary fan is it as easy as turn the ac on and listen for another fan to kick in.. lol i dont know where that is either.. thx..
Old Jul 14, 2009 | 01:15 AM
ghost6303's Avatar
theres the main fan that you can see is connected to the center of the engine. then there is another fan on the passengers side of the radiator that is run by an electric motor. you should be able to easily hear it kick in and you can see it moving if its on.
the coolant temp sensor can be replaced in under 5 minutes with a flat head screwdriver, just disconnect the sensor wire, pull out the clip thats holding it in, swap in the new one and put the clip and wires back on. its located at the very back of the engine, sort of down behind it, in the center. its between the engine and the firewall.
Old Jul 14, 2009 | 11:29 AM
screamin demons's Avatar
If the engine temp switch doesn't do the trick, the problem with mine not blowing cold air even with the AUTO button pushed and the temp at LO was the outside tempature sensor.
In your dash if the outside air isn't that hot then it won't run the AC. mine went bad and i had no AC because it thought it was 14degrees outside.
Old Jul 14, 2009 | 12:39 PM
ast03's Avatar
lol id check that but my little screen thing in the middle is broke... lol i pushed it once while i was driving just to see what would happen.. found out it is functional but the screen itself just doesnt work so i accidentally started a speed limit thing and every time went 20mph my car would keep beeping.... lol so i had to find an empty road and floor it to a fast speed then i pressed the button again.. so now it only beeps wen im going 110mph.. ill try that if this doesnt fix the problem though.. thx
Old Jul 14, 2009 | 05:13 PM
audi guru's Avatar
nice fix
Old Jul 14, 2009 | 10:08 PM
ast03's Avatar
does anyone have a pic of where the sensor is for an 01 1.8.. i googled it and cant find any that show an 01 other years seem to b different.. ive been staring at my engine for awhile now and i cant find it..lol i get the general area but every tube and plug seem to lead to something else.. i guess this is a 5 min job once u find it for me
Old Jul 15, 2009 | 03:10 AM
Veegard's Avatar
This could sound like the ac compressor belt being worn aswell? Has it been serviced?
