Adhesive for reattaching interior trim
On My daughters 2000 A4, the drivers side interior cosmetic trim piece that runs along the top of the window frame on the inside edge of the headliner is coming off. I tried a glue gun and it seemed to work just fine until a week later and then it reoccurred. What adhesive would be best and a permanent hold?
Thanks In advance mates!
Swankster
Swankster
I used contact cement when mine started to come off last summer. I pulled it apart as much as needed as the connection was weak to begin with as the glue was separating. Cleaned both surfaces with rubbing alcohol, applied a thin coat on both sides, let it dry until tacky and carefully applied even pressure while moving my hand along the trim. Just make sure to take your time and not stretch the molding too much or this will cause the trim to minutely bunch up when you get to the end. Good luck.
Doug
Doug
Thanks to all.
Swankster
irishaudi
Nov 25, 2013 05:35 AM
2001.5AUDIS4
May 1, 2010 10:37 PM
nismonewf
Nov 27, 2008 08:43 PM
