Advice please - Smokey AEB
Old Feb 19, 2012 | 03:20 AM
nzant008's Avatar
Default Advice please - Smokey AEB
I am having some continuous issues with my engine.
Problem:
After a drive, stop the engine and restart (say 10-20 minutes after) the car will blow some blue/white smoke. This smoke does not last for an extend period just till you get to about third get on take off and for about 5 minutes on idle. The car does not smoke while driving, on boost, at the lights.
Background:
I have had new rings installed, reconditioned the head (exhauset valve guides and stem seals), new oil pump, reconditioned turbo.
I am running out of ideas. The only possibility i have left is that the turbo has a hairline fracture which opens up when left after a drive.
Any advice? DESPERATION HAS TRULY SET IN!!!!!!
Old Feb 21, 2012 | 01:17 AM
bmoore98A4's Avatar
Hey man thats no good. But if you did the rings and the head, you may have increased the pressure inside the cylinder blowing the head gasket. Does the motor shake? Stutter? Boost is at 8ish lbs?
Old Feb 21, 2012 | 10:46 AM
MetalMan's Avatar
I know this might be a silly question, but you're sure the valve stem seals are properly installed? This behavior sounds like it could be from them... (it was on the Camry I used to drive, but those were the original valve stem seals)
How many miles are on your turbo?
Old Feb 21, 2012 | 07:55 PM
nzant008's Avatar
The motor does not shake not more than normally. Boost is at max 15psi (mine runs a K24 turbo) and different MAP.
Old Feb 21, 2012 | 07:56 PM
nzant008's Avatar
I am not sure about the valve stem seal, but i have checked the spark plugs and they have a nice grey color with white on the tips. If it was the valve stem seal then it would leave some oily residue on the plugs.
Old Feb 22, 2012 | 02:09 AM
bmoore98A4's Avatar
You are burning water for the white and oil for the blue. Obvious yes. But where do these two things meet near the head? water jackets, oil passages ect.
Brainstorm? lol
Old Feb 28, 2012 | 11:53 PM
nzant008's Avatar
Yes, but no water in sump and no oil in water reservoir.
Just lost for ideas really
Old Feb 29, 2012 | 04:06 PM
bmoore98A4's Avatar
the only thing i can even think of is to take the whole thing apart again...maybe it just needed to burn some gunk left over from before the build?
Martinfitz09
Nov 2, 2013 04:00 PM
NineInchNails
Mar 19, 2012 05:58 PM
nzant008
Feb 19, 2011 09:12 PM
nzant008
Feb 16, 2011 06:18 PM
martinlji
Sep 22, 2010 05:55 PM
