air bag question on b5
Old Dec 16, 2012 | 12:43 PM
Bruce Leroy's Avatar
Default air bag question on b5
98 b5 1.8t Quattro 5speed
After the air bags deploy will that cause your engine stall continuously when trying to start it. Does air bag module needs to be replaced or reset in order for the car to stay running?
Old Dec 16, 2012 | 12:53 PM
jonbonesjones's Avatar
Moderator
no your car should run fine after airbags go off. What caused them to go off?
Old Dec 16, 2012 | 07:06 PM
Ran over this tv that someone had out for garbage. And I wasn't paying attention. It cracked my oil pan and intercooler pipe in the front
Old Dec 16, 2012 | 08:05 PM
Moderator
bahahha, yea you messed something up. You should see what else you manages to fubar with that tv
Old Dec 18, 2012 | 12:08 PM
Dallas09's Avatar
+1 it does not.
Old Dec 18, 2012 | 12:30 PM
CCA4's Avatar
Do you have any check engine light or is it just the ABS light? Sounds like you may be in for a little more trouble than just a popped air bag...
Old Dec 18, 2012 | 02:16 PM
MetalMan's Avatar
Yeah... airbag deployment definitely won't cause the engine to not start. But you will need to replace the airbag module or forever be stuck with an airbag light (I know from experience).
Like others said, you've got something else causing the car not to start.
Old Dec 21, 2012 | 08:06 PM
Yea its my intercooler pipe causing it not to stay on cause its smashed and disconnected
Old Dec 21, 2012 | 09:15 PM
Moderator
DING DING DING, that will do it.
EvoTillIDie1
Mar 5, 2014 10:42 PM
manindra
Feb 10, 2009 05:59 PM
SouthernAudi
Oct 14, 2007 06:47 PM
viper771
Mar 7, 2006 05:52 AM
