Air Intake and Blow-off valve
Old Mar 17, 2008 | 07:51 PM
Sonasty's Avatar
Default Air Intake and Blow-off valve
Hey guys,
I have a 1998 A4 1.8T and Im looking to put in an air filter (not a full intake). I know they sell like K&N filters at the stores around here, but I'm not sure what size piping the A4 comes with stock. What size should I be looking for?
Also, I want to change the stock blow-off valve that the turbo uses for one of those aftermarket ones. Where can I order one that will be compatible to my car? Thanks a lot for the help. I don't know much but my friends can help me install the parts. Im not a huge car buff..
Old Mar 17, 2008 | 08:02 PM
cincyTT's Avatar
I'm make believe
Default RE: Air Intake and Blow-off valve
All you need is a 2.75" piping and filter. As for a dv, just go to ecstuning.com under intakes for a nice list of dv's, all high quality peices
Old Mar 17, 2008 | 08:11 PM
Sonasty's Avatar
can you elaborate on DV? Im tellin ya, im really a newb...
Also, is there a 'DIY blow-off valve install guide somewhere on the web? Im having trouble locating it but i THINK i did..
Old Mar 17, 2008 | 08:12 PM
turbo kraut's Avatar
Tech Guru
if you get a k&n anything...........make sure to let the oil dry..... sit it out for the night or wipe it down......... and unless you are just looknig for that psh sound, just buy a drop in filter
i had a cone filter it does nothing but make the dv louder and maybe a little and i mean little bit more responsive throttle over my drop in filter
Old Mar 17, 2008 | 08:32 PM
feerocknok's Avatar
What is the noise you want the blow-off valve to make?
Old Mar 17, 2008 | 08:50 PM
Sonasty's Avatar
feerocknok.. im looking for that "vrrrrrrrrr tsss" noise, but nothing over-the-top. Just a magnified stock sound basically.. but a nice one. Idk what the standard is but im hoping you know. How hard is it to install.
as for the intake, Ill take heed to what you guys said. I just want a filter tip basically, hopefully open cone.
Old Mar 17, 2008 | 09:38 PM
feerocknok's Avatar
The intake mod (more so with a cone filter and heatshield)will go "(engine) brooooooom- (let off throttle) foo".
I like people to type the other noise so I can laugh for an hour. Search "Psh sound" on this board and you'll see the humour.
Old Mar 17, 2008 | 10:29 PM
Sonasty's Avatar
Sick, thanks for the info.
The blow-off valve, where can I order one with my description that will fit my A4 1.8T '98? Is it a do-it-yourself at home mod?
Old Mar 18, 2008 | 12:04 AM
Sonasty's Avatar
Bump for answers for tomorrow =D
Old Mar 18, 2008 | 01:08 AM
chaos92287's Avatar
ORIGINAL: Sonasty
a dv recirculates the air back in, a bov vents it to atmospere
https://www.audiforums.com/m_732016/tm.htm
just skim the classifieds here and audizine. forge, baileys, apr are all good dv's. if you want a louder sound get a bov thats closed at idle like the forge 004, or hks ssqv. ssqv is annoying tho
funkymillah
Dec 3, 2007 03:20 PM
AudiStyle101
Apr 24, 2006 03:24 PM
seth1005
Aug 15, 2005 05:53 AM
Firestarter1984
Dec 10, 2003 03:06 AM
