Air lines that connect to solenoids on top of engine.
Old May 15, 2011 | 11:24 PM
pbbg's Avatar
Default Air lines that connect to solenoids on top of engine.
I need to replace the vaccum lines that connect to the solenoids. I assume these solenoids are for the cruise control. If you know where I can get these at and possibly how these lines are connected that would be huge.
Thanks
Old May 16, 2011 | 08:45 AM
ImTheDevil's Avatar
They control a lot of things including the manifold airways. Get the 3.5mm ID hose in your choice of color at www.siliconehose.com. Remove each hose one at a time and use it to cut a replacement to length, install, and move to the next one. It's a 45 minute job - nothing crazy involved.
Old May 16, 2011 | 09:34 AM
pbbg's Avatar
i knew it wasn't going to be difficult but unfortuantly some hoses are already broken but i think i will be able to figure it out.
hopefully.
Old May 16, 2011 | 09:38 AM
pbbg's Avatar
have your ordered from there recently? i can't find that specific diameter
Old May 16, 2011 | 09:44 AM
ImTheDevil's Avatar
A few of us ordered about a month ago. Here's a link to it:
http://www.siliconehose.com/commerce...per-vb-014.htm
PM me an email address or cell number and I'll send you a pic of mine up at the solenoid panel after I swapped them out. I'd post it here but uploading pics from my phone is a huge pain in the ***.
Old May 16, 2011 | 04:21 PM
Mad Cow's Avatar
Remember that if you get lost there's a vacuum line diagram on the underside of the hood, it really helps to use it to look over everything and make sure it's all right.
Old May 16, 2011 | 11:59 PM
pbbg's Avatar
thanks i got some from a local part store up the road and i didn't know there was a vaccum diamgram under the hood that is nice to know.
Old May 17, 2011 | 12:23 AM
roootasoo's Avatar
Also called Air Management System. I own an 1982 Chevy S10 2WD with a 2.8L V6 on a 4 speed manual (Federal Emissions).
///Maria
S4
Apr 26, 2015 10:28 PM
copper07
Mar 5, 2012 03:58 PM
agazoo
May 16, 2008 01:57 PM
Towlie
Jan 4, 2007 02:05 AM
aaronamericahall
Jan 26, 2005 03:24 PM
