Air Recirculation Valve Vacuum
Old Dec 20, 2012 | 09:50 PM
MyFreeAudi's Avatar
Question Air Recirculation Valve Vacuum
This valve will not hold a vacuum. And, there is just a little oil at the vacuum line connection when I replaced the vacuum line.
I have a P0171 CEL code, lean mixture. This lead to the replacement of this vac line and others.
There is no electrical connector to the valve so I believe it should always hold a vacuum.
So:
1. Should this valve always hold a vacuum?
2. Is the drop of oil bad news? If so, how bad?
Many thanks for any advice,
John
Old Jan 7, 2013 | 04:11 PM
MyFreeAudi's Avatar
Default Diverter Valve Problem Update
My online Audi shop manual calls this valve the Air Recirculation Valve. It is also called the Diverter Valve.
I replaced the valve with one from a junk yard:
HOME
If you are near Baltimore, this is a great place. I use the Hawkins Point Road yard which has a number of Audis and Passats.
The new valve holds a vacuum which the old one did not.
The bad news is that the P0171 CEL came on afterwards. So, I'll search the Forum for more advice on P0171, vacuum leaks, etc.
John
evilkowz
Sep 3, 2017 01:31 PM
SunnyShaida
Nov 20, 2008 11:35 PM
xxtaexx
9
Nov 18, 2007 02:44 PM
iamdaone187
Apr 22, 2007 02:24 PM
a3rullaz
Apr 2, 2007 12:42 PM
