Alright guys, I need some help.
Old Aug 31, 2011 | 01:23 PM
DOC_DEPALMA's Avatar
Default Alright guys, I need some help.
Recently put a new engine in my car, 2.8l 12v v6. After a **** ton of work over a period of a year plus, she won't start . The car is cranking, but I can't get it to fire. I checked my spark by touching the plugs to the intake manifold one at a time, and had no spark in either.
Also scanned with VCDS lite and came up with no engine codes (although cel is on). Where to start? I really need the help guys. If I don't make the fall meet the Devil is going to keep my soul, and I need it.
Old Aug 31, 2011 | 06:55 PM
airguard350's Avatar
Tech Guru
I had the same problem. How much gas is in the tank? Is it fresh or did you add fresh gas to old gas? Throw a bottle of seafoam into your gas tank and see if that don't help.
Old Aug 31, 2011 | 08:52 PM
The gas In there is incredibly old. I added some fuel stabilizer stuff to it, can't remember what it was. I'll try the seafoam tomorrow and update :-p
Old Aug 31, 2011 | 09:21 PM
Tech Guru
Well my car sat for 6 months with an 1/8 of a tank. A bottle or two of seafoam and a couple gallons of fresh premium helped it fire. Once it starts to catch, romp on it and hold it at around 2000 rpm for a couple minutes.
Old Sep 1, 2011 | 03:52 PM
K I'm hoping that's what the problem is here. If it is I'm totally sending you a sandwich.
Old Sep 1, 2011 | 08:58 PM
ImTheDevil's Avatar
I hope it works man. Fire that sumbitch up already!
Old Sep 2, 2011 | 12:53 AM
Tech Guru
Mmmmm.... Send muh sumthin' tasteh!
Old Sep 2, 2011 | 08:08 PM
Unhappy LONG POST. Sorry!
No luck with the seafoam. Ran an autoscan with VCDS-lite and the following was displayed::::::
VCDS-Lite Version: Release 1.1
Friday, 02 September 2011, 20:02:40.
Chassis Type: 8D - Audi A4 B5
Scan: 01,02,03,08,15,16,17,25,35,37,45,55,56,57,67,75,76 ,77
Address 01: Engine Labels: Redir Fail!
Controller: 8D0 906 266 B
Component: 2,8l V6/2V MPI OBD2 D02
Coding: 01201
Shop #: WSC 06335
VCID: 2B2984AFCA0B
No fault code found.
Readiness: N/A
Address 03: ABS Brakes Labels: 4D0-907-379-ABS.LBL
Controller: 4D0 907 379 L
Component: ABS/EDS BOSCH 5 4171
Coding: 0265109043
Shop #: BB 34171
VCID: 3701A8DF0643
1 Fault Found:
00290 - ABS Wheel Speed Sensor; Rear Left (G46)
30-00 - Open or Short to Plus
I don't understand what the part that reads Label: Redir Fail! means... and am also thinking that with my CEL on that I would have some kind of DTCs other than the ABS ****.
Another thing, displayed on the monitor between the tach and spedo there are some flashing symbols, one being an oil can with drippy drops falling, and above that in the yellow region is some kind of beaker looking symbol that is spouting some kind of fluid. Can anyone identify these for me? Hoping I can get pointed in the right direction.
Old Sep 2, 2011 | 08:14 PM
One more thing, in my odometer under my mileage flashes a "ln 2" over and over. What gives with this?
Old Sep 2, 2011 | 08:22 PM
Tweaked's Avatar
^Bad, dangerous, no-no!!!
Is it a tiptronic? If so, be sure the TCM is plugged in and code-free. If you've yanked the engine, you've unplugged a lot of stuff... something is probably not plugged in. Crank position sensor, TCM, coil pack...
Also, I believe ln 2 is just a service interval light.
