Another timing belt!
Old May 20, 2010 | 08:59 AM
02A6Beau's Avatar
what he said
mark the sprockets to the engine, mark the old belt to the sprockets, mark the new belt the same number of teeth apart as on the old belt after you take it off, then when you reassemble ALL the marks should line up (not entirely necessary but why take chances)
the only part that I had issues with is making sure the new belt was seated in the water pump pulley correctly before trying to go around the second cam sprocket. If its not in there right the belt wont stretch far enough (and its only like a centimeter off but enough to keep you from getting the belt on the sprocket)
Old May 21, 2010 | 03:16 AM
yamaharider11161990's Avatar
alright thanks alot guys. and i am still lost about the hydraulic tensioner. i dont know if it is just the pulley that does it or what for the 12v? the kit on blau doesnt have it...although the kit on ecs for 350 has one? idk if i should buy the blau kit and purshace one seperately or if it is like you said and just for the 30v
Old May 22, 2010 | 01:26 PM
anyone please? i need to know what to order?
Old May 22, 2010 | 01:29 PM
NickBroderick's Avatar
Everytime I see a TB thread I cringe because mine is 170,321 miles old .
Old May 22, 2010 | 02:03 PM
JETSPEED333's Avatar
SoCal Crew Member
buy a new hydrolic tensioner... this part is different from the pully... replace both... the tensioner is not cheap... i ended up buying it from audi.... about $170
Audiguruforyou
Sep 20, 2011 01:31 AM
vtraudt
Apr 1, 2011 09:40 AM
TheBat
Jun 20, 2008 01:14 PM
