Anti Freeze leak Help.
Old May 15, 2011 | 06:48 PM
crazyone's Avatar
Default Anti Freeze leak Help.
On the last couple of days, I have noticed small puddleof Anti Freeze Liquid under my car and yesterday the Light went On for Low Anti Freeze Fluid. So I looked under the Hood for the common places and Water Pump, Radiator Looked Fine. Thermostat looked also fine. I noticed a little trickle from the back of the engine. I looked with a mirror and I could not see the Source of the Leak.
Does anyone have any suggestions to where to look back there? The Worst I can think off is cracked block but I am not overheating and I can drive fine. I wonder if this is common problem .
Old May 15, 2011 | 08:30 PM
audiltr's Avatar
Check around the oil cooler or under the intake manifold on the block
Old May 15, 2011 | 09:24 PM
crazyone's Avatar
Default Leak
I was searching for the Leak until I ran into other problems. At the same time I was changing my Oil and when I went to put the plug back in, the Drain Plug Washer Broke on me. So I have to order a new one and until I get that, I can not run the engine.
I have a funny feeling it is the Cylinder Cooling Flange in the back of the Engine. Part#058121132 I read somewhere that is a common problem with Leaks. My Car will be down for a while until I get the freaking Oil Plug.
Old May 15, 2011 | 10:18 PM
audiltr's Avatar
You can get a washer from the dealer for free!
Old May 15, 2011 | 10:32 PM
Audi_B5's Avatar
I have the same leak from the back of the motor! i cannot see anything leaking though... :/
Old May 15, 2011 | 11:30 PM
crazyone's Avatar
I have to work. Audi Dealer is 10 Miles in the opposite Direction for me.
As far as the Leak to the Flange, there is a Hose that goes from Heater Core to Flange that also has to be replaced. I ordered the parts but want to wait until I get the oil plug and run the engine for a while and snoop around the back. I really want to see where it is leaking. Kind of hard looking for leaks when it is raining hard too.
Mike Mulligan
Nov 1, 2012 04:10 PM
zblad
Jan 18, 2011 01:59 PM
Collinsd
Jan 8, 2009 11:21 AM
clayton787
May 12, 2006 06:08 PM
Dj Spiel
Oct 17, 2005 04:17 PM
