anyone know bout VW tiptronic modules?
Old Apr 23, 2008 | 02:51 AM
jude14601's Avatar
Default anyone know bout VW tiptronic modules?
Today at the wrecking yard I found a 98 Passat that had a five speed tiptronic which seemed identical to the one in my 99.5 2.8. My transmission works fine EXCEPT that the tiptronic is completely non-operational. I believe this may be due to the previous owner spilling starbux (repeadtly, sigh...) all over the dash, which i think has seeped down into the tiptronic module. I'm wondering if the one out of the passat will work, even though i believe it was a FWD car. anyone know if these are interchangeable regardless of drivetrain?
Old Apr 23, 2008 | 03:42 AM
david9999's Avatar
Default RE: anyone know bout VW tiptronic modules?
Don't know if that will work, but the usual cause of tiptronic not working is that the magnetic strips in the module get loose. This is a common problem and is a cheap fix. There should be several threads on this issue with pictures and DIY instructions.
Old Apr 23, 2008 | 04:34 AM
jude14601's Avatar
sorry to be a PITA, but do you mean the threads are in the A4 forum section, or the general forums tech section? Could you maybe link me there>? much appreciated
Old Apr 23, 2008 | 10:19 AM
david9999's Avatar
Try this:
http://forums.audiworld.com/a6/msgs/705947.phtml
Old Apr 23, 2008 | 12:07 PM
powersmokin's Avatar
here is one tip that will save you a ton of frustration the magnet switch only works on one side of the magnet.
Ricston
Mar 23, 2014 08:11 AM
ericp1.8T
Oct 9, 2011 11:44 PM
markymarc
Sep 18, 2010 05:39 PM
outlaw24
Dec 16, 2008 08:03 PM
KTwo
Nov 1, 2008 03:52 PM
