Audi A4 1.8T '96 startup problems.
Old Sep 3, 2015 | 11:59 AM
martin9400's Avatar
Default Audi A4 1.8T '96 startup problems.
Hi guys, I'm new here and just registered to see if I can get something out of the VCDS faults I got on my car. The car starts when I turn the ignition but shuts down around 1-2 seconds after it starts, just dies. I pulled out some fault codes, but I can't really make any sense of it. I thought it had something to do with the immobilizer, but there aren't any fault codes on it. So I don't really know what the problem might be, but I really want my car back on the road.
Posting the fault codes:
VCDS-Lite Version: Release 1.2
Thursday, 03 September 2015, 17:58:25:0
Chassis Type: 8D - Audi A4 B5
Scan: 01,02,03,08,15,16,17,25,35,37,45,55,56,57,67,75,76 ,77
Address 01: Engine Labels: None
Controller: 8D0 907 557 T
Component: 1.8L R4/5VT MOTR HS D04
Coding: 04001
Shop #: WSC 00000
VCID: 41F5C6075891
4 Faults Found:
18010 - Power Supply Terminal 30: Voltage too Low
P1602 - 35-10 - - - Intermittent
17967 - Throttle Body (J338): Fault in basic settings
P1559 - 35-10 - - - Intermittent
00561 - Mixture Adaptation
14-10 - Adaptation Limit (Add) Exceeded - Intermittent
Readiness: N/A
Address 03: ABS Brakes Labels: 8E0-614-111-ABS.LBL
Controller: 8E0 614 111
Component: ABS 5.3 FRONT D11
Coding: 0273004132
Shop #: BB 24303
VCID: DBC9946F5A3D
No fault code found.
Address 08: Auto HVAC Labels: 8L0-820-043-2D.LBL
Controller: 8L0 820 043 B
Component: A4 KLIMAVOLLAUTOMAT_D72
Coding: 04140
Shop #: WSC 06435
VCID: 2721789FD6F5
Address 15: Airbags Labels: 8A0-959-655.LBL
Controller: 8A0 959 655 C
Component: Airbag V AUDI D01
Coding: 01022
Shop #: WSC 06324
VCID: 33199CCF122D
1 Fault Found:
00532 - Supply Voltage B+
07-10 - Signal too Low - Intermittent
Address 17: Instruments Labels: 8D0-919-0xx-17.LBL
Controller: 8D0 919 034 F
Component: B5-KOMBIINSTRUMENT__D12
Coding: 00142
Shop #: WSC 00186
VCID: 2C2B87B3CF13
Address 25: Immobilizer Labels: 4A0-953-234.LBL
Controller: 4A0 953 234
Component: IMMO AUZ9Z0M3344440 D77
Coding: 00000
Shop #: WSC 00600
VCID: DFB1A07F4E25
Address 35: Centr. Locks Labels: 8D0-862-257.LBL
Controller: 8LO 862 257
Component: ZV-Pumpe, DWA, Funk
Coding: 10184
Shop #: WSC 65535
VCID: 115536474871
8 Faults Found:
01367 - Central Locking Pump Run Time Exceeded (Likely Leak)
35-00 - -
01371 - Alarm triggered by Door Contact Switch; Driver's Side
35-00 - -
01372 - Alarm triggered by Door Contact Switch; Rear Passenger Side
35-00 - -
01374 - Alarm triggered by Terminal 15
35-00 - -
01370 - Alarm triggered by Interior Monitoring
35-00 - -
01369 - Alarm triggered by Hood Switch
35-00 - -
01368 - Alarm triggered by Luggage Compartment Switch
35-00 - -
01373 - Alarm triggered by Radio Ground Contact
35-00 - -
End --------------------------------------------------------------------------------------------------
Old Sep 3, 2015 | 11:08 PM
george1546's Avatar
Does your car start up at all after the initial shut downs? Or is this a repetitive thing where it starts and shuts down in 1-2 seconds and this just keeps repeating. (start/shutdown, start/shutdown etc)
Old Sep 4, 2015 | 01:04 AM
martin9400's Avatar
Starts and dies, over and over, until the battery is empty
Old Sep 4, 2015 | 11:31 AM
george1546's Avatar
That's interesting, reason I ask is I had a similar problem but mine would shut off the first few start ups and then fire up fine for the rest of the day. My issue was the piping in the diverter valve had a hole and im assuming as it was off through the night air starts creeping into the intake via the hole hence causing problems on first few startups until it clears it all out.
I would suggest checking the immobilizer again, just cause there are no codes shown for it does not mean there isn't a fault in the system. Also check the terminals to the battery and the grounds for the engine.
Old Sep 14, 2015 | 07:53 PM
turbo510's Avatar
Sounds like a fuel problem to me. You've got a lean-code, so I'd check that you have fuel pressure. You can arrange a "T" fitting into the pressure line leaving the top of the fuel tank, and then see what reading you get when attempting a start.
Old Sep 16, 2015 | 10:37 AM
martin9400's Avatar
After a bit of fault searching and checking the relay etc, I found the pump to be faulty and well, not pumping anything at all. So I need a new fuel pump.
Thanks for all the help
Old Sep 16, 2015 | 12:35 PM
elduderino200's Avatar
And you're sure the battery isn't just dead? If there's no power to anything, they'll all fail to work.
Old Sep 16, 2015 | 12:41 PM
martin9400's Avatar
I'm sure the battery isn't dead as the car tries to turn on, and all the electronics works when the ignition is on. But I measured with a multimeter through the pump itself, and the pump is dead. Also tried turning it on with the fuel line stuck into a bottle, and well. No fuel came out when I tried starting it. So yeah, pretty sure that the pump is at fault there. Also checked the relay with a 12V car battery of another car, and there is no problem with the relay.
Did get help with the fault-searching from my dad who has been a mechanic aboard everything from his scooter when he was a teenager all the way to huge drill-rigs. Also of note, he's the technical leader on a rig as we speak. So chief of everything from electronics to the engines. I think I can trust his word on the pump problem
Old Sep 16, 2015 | 03:06 PM
Yes, that's nice and all, but are you REALLY sure?
naw kidding sounds like it aint the battery.
Old Sep 16, 2015 | 03:09 PM
martin9400's Avatar
Yeah, I see that you're a bit of a joker right now, but the fact that the car tries to start and the voltmeter in the dash says it's about 12 volts tells me that it ain't the battery. Also the fact that I tried with a jumpstart a couple of times still to no avail. So I should just look into getting myself a new pump and the problem will probably be solved.
Even though I kind of don't want it to be solved as I get to drive my dads Coupe GT in the meantime, god that engine sounds so good, even though it's eating up my finances with it's premium fuel need
imranmalik
Feb 9, 2012 12:19 AM
chrise12287
Oct 17, 2011 05:27 PM
keef1979
Aug 3, 2010 11:45 PM
flavio
May 13, 2008 04:28 AM
