View Poll Results: Its rpm issue or relay issue
Relay issure
0%
Multiple Choice Poll. Voters: 1. You may not vote on this poll
Audi a4 b5 A/C issue
Hii
My ac compressor isnt work on,when i check by vcds,it showing compressor shut-up by (engine rpm lower than 300rpm).in measuring
diagram my rpm value is 0
Dashboard rpm and engine control module showning rpms are okey
please help
please help
It’s most likely not enough pressure in the system to activate the pressure switch and turn on the electromagnetic clutch. You can check the pressure in the system using VCDS advanced measuring blocks/pressure. If it’s low on refrigerant, the clutch won’t activate due to low pressure so you may need an AC top up.
