View Poll Results: Its rpm issue or relay issue
Rpm issure
100.00%
Relay issure
0%
Multiple Choice Poll. Voters: 1. You may not vote on this poll
Audi a4 b5 A/C issue
Old Aug 19, 2023 | 03:31 AM
shamal.kahaduwa.galaxy@gmail.com's Avatar
Default Audi a4 b5 A/C issue
Hii
My ac compressor isnt work on,when i check by vcds,it showing compressor shut-up by (engine rpm lower than 300rpm).in measuring
diagram my rpm value is 0
Dashboard rpm and engine control module showning rpms are okey
please help
Old Aug 21, 2023 | 01:49 AM
Cybersombosis's Avatar
It’s most likely not enough pressure in the system to activate the pressure switch and turn on the electromagnetic clutch. You can check the pressure in the system using VCDS advanced measuring blocks/pressure. If it’s low on refrigerant, the clutch won’t activate due to low pressure so you may need an AC top up.
AlmandsL
Jun 24, 2018 06:32 PM
RandyCibao27
Aug 19, 2016 08:11 PM
kenman
Sep 17, 2012 09:22 AM
JeremyT1169
Jul 7, 2012 05:35 PM
RoccoConQueso
Apr 29, 2012 02:37 PM
