Audi A4 B5 Model HID Install
Well, I recently got my HID's in the mail.. going to install them today. (My Audi didnt come stock with HID's) You guys have any suggestions? Anything you have come across while installing? So far I am happy with how fast they came and the price.. hopefully the install goes well.
ya try to mount your ballast as far away from your engine as possible. if you have the one piece oem headlights, you'll need to drill a hole on the cap that you take off to get to the bulb. i'm not sure what you have to do for a 2 piece headlight though
Yep, either way with the OEM lights, a hole has to be drilled. Depending on the model of the car, mounting the ballast can be a little pain or very easy. On the driver's side, you can put it immediately behind the PS reservoir, between that and the ABS module. On the passenger side, it's a little more tricky. If you have an air intake and a 2.8L engine, there is a bolt that was used to support the OEM airbox, mounted into the fender, and that's a great place to mount it. For a recent 1.8T HID install done at my house, I did the driver's side and Hiwords did the passenger side. Due to how close the airbox sat to the headlight, he removed the headlight and mounted the ballast inside the fender behind the light, and we ran the wiring in from there. Not difficult at all to do, but you may have to think along those lines in order to mount it. You can also mount the ballasts below the headlight support frame (part of the front structure of the car, but it involves a little trial and error for placement and drilling holes for mounting bolts. Ultimately that's the cleanest way to do it - the tradeoff is the extra time for install.
pretty much covered it ...I did the same as the guy above on mounting but on the passanger side you can mount the ballast above and to the rear of the stock airbox
take your time drilling out the holes in the plastic light covers make sure the grommets just fit..you dont want any water leaking in there
good luck..you will be stoked best upgrade for the money on headlights! They look great and function wayyyyy better
Wow thanks for all the great help guys! I called the company where I got the lights ( www.xenoneyes.com ) and they helped me with the few questions I had. I have only seen the lights during the day so I cannot wait to throw them on at night! Can't WAIT!
Also, i would recommend the company I got it from as there is always someone there answering the phone. Gotta love that.
Thanks again!
Thanks again!
cukilo
Jun 11, 2006 02:45 PM
