audi a4 engine???
Old Aug 31, 2011 | 10:21 AM
Papa_Dios's Avatar
So when guys go BT and have 01.5's (AWM) and swap to the large port head (AEB) they do so knowing it will not work as you state? The only thing not on there would be the VVT/breather tube from the head and a couple of other things but it would definitely "work". If you can find the part #'s for the different K03's that came on our cars i'd be more than happy to retract my statement in regards to that.
Old Aug 31, 2011 | 10:27 AM
cincyTT's Avatar
I'm make believe
Yep, none of his accessories would fit and he would hate life and you screwed him. And you are correct, there is no "s" turbo. We enthusiast named it that. However there is a difference between them. The blade count is fewer for better results at higher pressure along with a bigger compressor on the revamped "s" model.
Ko3 - 97-2000
COMPRESSOR WHEEL
Inducer: 33.6mm
Exducer: 46mm
Tip height: 3.7mm
TURBINE WHEEL
Inducer: 45mm
Exducer: 38mm
Tip height: 6.8mm
Blades: 11
Ko3S - 01+
COMPRESSOR WHEEL
Inducer: 38mm
Exducer: 51mm
Tip height: 4.4mm
TURBINE WHEEL
Inducer: 45mm
Exducer: 38mm
Tip height: 6.8mm
Blades: 11
Old Aug 31, 2011 | 01:33 PM
FASTER's Avatar
Tech Slut
No, that is completely different. You can use an AEB head on either 1.8t block (058 or 06a) with little modification, however, we are talking about an aeb/058 car, and what engine setup it needs. You claim "a 1.8 is a 1.8" which simply isnt true. He needs an 058 block to be able to use his accessory drive and, even more importantly, so his ecu and wiring harness will be compatible with the engine. This thread is over, you don't understand what you're talking about, and shouldn't be giving out wrong advice that could cost people lots of money and headaches.
/Thread
Old Sep 1, 2011 | 10:20 AM
jonbonesjones's Avatar
Moderator
I think he is just trying to understand and your honestly not helping. Besides where's the OP I just want to buy your engine and help you out
Old Sep 1, 2011 | 03:11 PM
cincyTT's Avatar
I'm make believe
He is not getting the blocks are different in the AEB and ATW than all the other blocks made. So a 1.8 is NOT a 1.8
curtmon03
Mar 19, 2012 08:35 PM
curtmon03
Oct 4, 2011 07:49 PM
winner007
Mar 4, 2007 01:50 PM
xxipsxx
Jan 1, 2007 05:30 PM
42, 99, a4, b5, dbc, dbw
