Audi misfiring code but doesn't seem to be missing?
Old Sep 27, 2012 | 06:23 PM
Pbcrazy's Avatar
Default Audi misfiring code but doesn't seem to be missing?
My 98.5 Audi a4 1.8tQ got a check engine light today while driving, iBook it to autozone and it said it was missing on cylinders 1 and 3 and another random misfire. Now the car seems to be running fine for the most part. Are these faulty codes or should I replace the coils? I just replaced the spark plugs about 500 miles ago
Old Sep 27, 2012 | 06:37 PM
MetalMan's Avatar
Did you search? This is pretty common.
http://www.google.com/#hl=en&sclient...w=1663&bih=706
Old Sep 27, 2012 | 06:45 PM
Pbcrazy's Avatar
I did do a search and didn't and still dot see anything like 2 or 3 cylinders misfiring but sound fine
Old Sep 27, 2012 | 09:05 PM
Pbcrazy's Avatar
Any way to test ignition coils?
Old Sep 28, 2012 | 06:08 AM
Pbcrazy's Avatar
Anybody?
Old Sep 28, 2012 | 06:35 AM
bradtyler02's Avatar
clear code, swap coils to 2 and 4, drive, rescan. If the miss moves to 2 and 4, you need new coils. if the miss stays at 1 and 3, it's something else.
Old Sep 28, 2012 | 10:22 AM
redline380's Avatar
Legal Moderator
since my knowledge of aeb's sucks, dont quote me on this but on gm cars, #1 and #3 on four cylinders are on the same coil. if its the same with audi, id suspect the ignition control module, which is also problematic.
Old Sep 28, 2012 | 10:39 AM
Pbcrazy's Avatar
What's an aeb? And should I try replacing the control module or the ignition coils?
Old Sep 28, 2012 | 10:41 AM
jonbonesjones's Avatar
Moderator
AEB is an engine code
swap the coils, thats priority number one
Old Sep 28, 2012 | 10:44 AM
Pbcrazy's Avatar
So my engine is an aeb? and I can buy a new set of 4 coils for about $80, should I try but them and if it doesn't work put the stock back on and try the control module?
