Audi misfiring code but doesn't seem to be missing?
Old Sep 29, 2012 | 12:31 PM
  #21
Pbcrazy's Avatar
First 2 are from cylinders 1 and 3 ( the ones that were "misfiring")
Second two are from 2 and 4
Old Sep 29, 2012 | 12:56 PM
  #22
Pbcrazy's Avatar
I'm starting to think my fuel injectors are clogged, it hard starts when cold, I had a misfiring problem, and I feel hesitation when I gas it. Any second opinions on that theory?
Old Sep 29, 2012 | 05:51 PM
  #23
jonbonesjones's Avatar
Moderator
plausible, since you already did the filter I would say next shot is injectors. They are easy to pop off and clean.
Old Sep 29, 2012 | 07:25 PM
  #24
CCA4's Avatar
Plugs look pretty damn good to me. Were they wet when you took them out?
Old Sep 29, 2012 | 08:24 PM
  #25
Moderator
also possible short causing the misfire. were the coil packs in tight ?
Old Sep 29, 2012 | 08:43 PM
  #26
Pbcrazy's Avatar
Plugs were not wet but the car hasn't run in 12 hours, the coils and plugs were tight. How exactly do I clean injectors? I want to take them out and do them not use techron. What's the most effective and easiest way for a regular dude to clean them correctly?
Old Sep 29, 2012 | 11:49 PM
  #27
Pbcrazy's Avatar
Gapped the plugs to .028 inches, they were all between .034 and .038. Started up but I still think I may have a fuel injector problem, anybody know the est way to clean them without and other those rigs people uses with the switches?
Old Sep 30, 2012 | 12:05 AM
  #28
bradtyler02's Avatar
That might not be the only issue, but it definitely wasn't helping. You should feel much better response from the engine.
As for cleaning the injectors, do a search for seafoam treatment. Good stuff. I use the following method with good results:
One full can in a full gas tank. Half can in the crank (where you add the oil to the engine) and a half can through the vacuum line on the intake manifold. Change your oil when it's time to refill the gas (about 300 miles).
Old Sep 30, 2012 | 12:14 AM
  #29
Pbcrazy's Avatar
I just did the seafoam treatment about 200 miles ago. I think either the injectors are too clogged for that to do much or my injectors arnt the problem. I ran it through the crankcase, the tank, and the intake. One thing I know for sure is that the engine is not getting enough fuel, I can feel and hear it.
Old Sep 30, 2012 | 01:57 PM
  #30
mk4cam's Avatar
Wow didn't know the bkr7e went all the way to .038 without being compensated. Definately needs to be around .028 (or less). I had mine all the way down to .022 to stop misfires before I decided to upgrade to 2.0 ignition.
Have you thought about doing the fuel filter, its cheap and easy.
