audi noob needs a little help
Old Sep 5, 2013 | 09:14 AM
antonioljn's Avatar
Default audi noob needs a little help
I have owned VW since I learned to drive and now have upgraded to audi.
This is my first audi, got me an a4 1.8t Quattro b5. Just need some direction on the few issues im seeing:
1. To start the LCD pixels aren't all lit but im able to make out the symbol in the middle that looks like a rotor (brakes need to be changed)
2. ABS/Brake light come on when going 60-65mph, 3 beeps and blinks until im turn off the car. If I keep it at city speeds it never comes on.
3. LCD is also showing the text " BRAKE LIGHT", not sure if related to worn brakes or bulb that might need replacement
If anyone can provide a little info on these issues I would really appreciate it.
thanks in advance.
Old Sep 5, 2013 | 12:15 PM
redline380's Avatar
Legal Moderator
thanks in advance.
number 1 and 3 are common issues. try the search function next time. for number 1, I don't really know what the question is. if you need to change the brakes, change them. brake light lit up means you have a bulb out.
number two is a little more iffy. i'd imagine you have a bad abs sensor or tone ring on a cv shaft. the fact that it is speed related makes me thing it is losing the abs signal
Old Sep 5, 2013 | 01:28 PM
antonioljn's Avatar
Well for #1 just wanted to know if there is any way to fix the LCD ? Thanks for the advice by the way
Old Sep 5, 2013 | 02:08 PM
MetalMan's Avatar
Yes. You can buy the LCD and desolder the old one and solder in the new one yourself (that's what I do, requires a good amount of soldering skill), or you can pay to have it done.
Replacement Aftermarket LCD - $50.00 : Reflect Tuning :: SHOP
Replacement OEM LCD - $95.00 : Reflect Tuning :: SHOP
LCD Replacement (Aftermarket LCD) - $110.00 : Reflect Tuning :: SHOP
LCD Replacement (OEM LCD) - $180.00 : Reflect Tuning :: SHOP
Old Sep 5, 2013 | 02:17 PM
Mad Cow's Avatar
Usually the ABS light coming on at speed means one sensor or it's corresponding ring is dirty. Just spray the hell out of both with some brake cleaner and see if it helps, if not you'll probably need to change the sensor.
Old Sep 5, 2013 | 03:21 PM
antonioljn's Avatar
thanks everyone I really appreciate the advise!!
Old Sep 5, 2013 | 03:44 PM
ECS Tuning's Avatar
Sponsor
We have the entire North American Parts Catalog LIVE & Search able on our site if you ever need to obtain OEM parts pricing!
We also have the ability to source all available European OEM parts as well!
At the top right hand corner there's a search box where you can type in part numbers or look up the part by name.
Check it out HERE!
Let me know if you have any questions.
Jason
Tnhines
Dec 11, 2013 12:18 AM
Destined2Race
Jun 25, 2012 02:04 PM
mtesor106
Mar 29, 2011 11:27 PM
Ivan_Chokibich
Apr 23, 2009 03:08 AM
phila1776
Dec 12, 2007 12:38 PM
