Auto transmission removal
I have the bentley service manual. They refer to audi tools to do the job, I was hoping that the special tools are not needed. They also say that you need to support the engine from the top, is this needed. They say that you need to remove the front end of the car and ac condensor to remove the starter, is this true.
Were you able to remove the trans with a floor jack? Looks like the transmission is alot heavier then other transmissions I have removed.
i got the trans out with a floor jack.
You shouldn't need any special audi tools
the starter doesn't have to be removed from the car, just take the bolts out that go through it.
The engine doesn't really have to be supported, but it is a good idea, it wil be held by the engine mounts but the rear of it is supported by the trans. Always better to be safe than sorry.
Did you get the torque converter bolts without pulling the starter all the way out?
no but the converter was still on the engine? i didn't need to take it off, lol it sounds like it should be attached,
