Auto transmission removal
Old Aug 21, 2012 | 10:16 PM
mrk3cobra's Avatar
Default Auto transmission removal
Looking for online guide to removing auto transmission from 2000 a4...
Old Aug 22, 2012 | 06:29 PM
mtroxel's Avatar
I don't know that there is one out there. It's a big job. I've done it, but I followed Bentley. I'd advise you to invest in a Bentley for that job.
Old Aug 23, 2012 | 02:05 AM
mrk3cobra's Avatar
I have the bentley service manual. They refer to audi tools to do the job, I was hoping that the special tools are not needed. They also say that you need to support the engine from the top, is this needed. They say that you need to remove the front end of the car and ac condensor to remove the starter, is this true.
Were you able to remove the trans with a floor jack? Looks like the transmission is alot heavier then other transmissions I have removed.
Old Aug 23, 2012 | 07:43 AM
jonbonesjones's Avatar
Moderator
i got the trans out with a floor jack.
You shouldn't need any special audi tools
the starter doesn't have to be removed from the car, just take the bolts out that go through it.
The engine doesn't really have to be supported, but it is a good idea, it wil be held by the engine mounts but the rear of it is supported by the trans. Always better to be safe than sorry.
Old Aug 23, 2012 | 07:46 AM
mtroxel's Avatar
Mine was the 2.8, and you have to remove the alt to get to the starter. I used no special tools. You do need to support the motor. I used this special tool for that:
Old Aug 23, 2012 | 07:48 AM
mtroxel's Avatar
Did you get the torque converter bolts without pulling the starter all the way out?
Old Aug 23, 2012 | 07:53 AM
Moderator
no but the converter was still on the engine? i didn't need to take it off, lol it sounds like it should be attached,
Old Aug 23, 2012 | 07:58 AM
mtroxel's Avatar
Yea I think I'd run a good chance of screwing up the pump seal if I tried to take the trans off the torque converter while it's still attached to the motor.
Old Aug 23, 2012 | 08:01 AM
Moderator
I see what you mean. I would take the starter out and unbolt it all then. Starter is a bitch to get at.
Old Aug 23, 2012 | 08:17 AM
mtroxel's Avatar
Absolutely!
