Is Automatic ECU same as Manual ECU ?
Old Feb 26, 2010 | 11:20 PM
MartinCieslak1's Avatar
Default Is Automatic ECU same as Manual ECU ?
Hi,
My engine cuts and loses all power for a short moment at random moments(no check engine). I changed all four spark plugs and it happens less often, but the problem is still there. So i'm going to change the four coils and I have a spare ECU from the same year but from an automatic quattro. My car is fwd manual, so are the two ECU's the same ?
thanks
Old Feb 26, 2010 | 11:26 PM
jjcrt2's Avatar
no they are different
Old Feb 28, 2010 | 12:28 PM
corwin06's Avatar
Member
what does your car do when it dies? i think i have a problem with my ECU just wondering if they are the same symptoms, mine will work fine one minute then the next when i floor it, it wont get past 3000 rpms have almost no power then it will just kill and need to be jumped..... had to push it a mile back home last time i drove it to the car wash
Old Feb 28, 2010 | 03:19 PM
FASTER's Avatar
Tech Slut
Why do you say that? The only difference should be the tcu for the automatic no?
Just pull the cover off the plastic box that its in and see if the numbers match. If so your good to go.
caseyg92
Nov 2, 2014 02:05 PM
Waterkotte20
B8 Models
9
Jul 30, 2012 04:16 PM
Superdug
Aug 17, 2008 11:39 AM
rlubbers
Feb 27, 2008 04:48 PM
johnstef
Sep 3, 2006 02:06 PM
