b5 Battery Life - wow
Old Jan 14, 2013 | 11:55 AM
hartsoe1's Avatar
Default b5 Battery Life - wow
I just removed my battery as it just barely cranked the car yesterday and after driving for awhile it would not charge back up. Manf date on it is Sept 04. Wow, those darn Germans (it is VAG OEM) - only 8.5 years on it. The car has been a DD since I got it third hand in early 2006. 189,000 miles with cold winters. I wonder how much these cost at the dealership? I'm replacing with an autozone duralast.
By the way, those plastic phillips head 'screws' on the plastic trim at the windshield are only quarter turn clips. That's why yours (and mine) are probably stripped, as I kept twisting past quarter turn. cheers
Old Jan 14, 2013 | 06:40 PM
Mad Cow's Avatar
OEM batteries are tanks, I bought a B5 this summer with an OEM battery from '03. If you call around you'll definitely be able to get one for less than $150, IMO it's very worth the extra cost.
Old Jan 14, 2013 | 08:50 PM
kriptonik's Avatar
Bosch batteries are good too!
Old Jan 15, 2013 | 06:05 PM
Slowb5's Avatar
did you have a vat test performed on your alternator? odds are theres a reason why the things got no juice.
Old Jan 15, 2013 | 06:21 PM
hartsoe1's Avatar
nope. I was getting 14 volts on the dash. no idiot lights. but, good point. I hope all is well.
Old Jan 15, 2013 | 07:05 PM
Slowb5's Avatar
yaya, id say a good 35 percent of the cars i see at the dealership end up having some problem with the alt. voltage regulator, failing in general...shitty bearings lol, id say give it a look see and lmk what you find.
Old Jan 15, 2013 | 09:25 PM
hartsoe1's Avatar
35% failures? I wonder if that is because people keep their Toyotas even longer than we keep our Audis?
Old Jan 17, 2013 | 06:42 AM
ChrisKingfisher's Avatar
yep daughter has just had to have a new alternator, in her A3 Sportback, as bearings broke up.
We have a 1999.5 1.8QTS,bought new, first battery lasted 7 years 2nd is still fine ( dangerous to say that !!)
Just replaced the battery on my B6 QTS after 8 1/2 years, with hindsight it had been slightly sluggish strating ( used to flick the key and it was running - had to hold the key over for thee seconds + to get it to run) and then without further problems it just wouldn't start one day -- nothing, virtually no volts, but it did start with jump leads . I bought a new battery - 8.5 years is OK in my book !
irussel
B7 Models
Jun 7, 2011 01:53 PM
B7Night
B7 Models
Jul 24, 2010 05:13 AM
S4Bennett
May 25, 2010 07:31 AM
rob12098
Dec 25, 2007 09:33 AM
dudley doright
Aug 10, 2005 11:29 AM
