B5 motor and 6 spd trans swap
Old May 28, 2013 | 06:09 PM
Mhuntington's Avatar
Default B5 motor and 6 spd trans swap
So my b5 2.8 motor has 210k on it. The 5 SPd trans has a bent synchro for 2nd gear. I don't want a new car. I want to build this one up. So with the mileage and trans issue, I'm looking to swap the motor. I want to make this cost as little as possible. I can't decide on a vr6t, 1.8t, 2.7t or 2.7tt. Which ever is less costly. I want to make around 400 awhp when it's done and it will have boost. Any thoughts ideas, suggestions? Are there other things I need for the trans swap?
Old May 29, 2013 | 03:32 AM
redline380's Avatar
Legal Moderator
this is one of those posts that has been discussed more times than anyone who has frequented this site for more than a year can remember. all of those motors are viable options, and all have been swapped successfully. i really dont care to write multiple pages on the subject, so if you have specific questions i'll answer them.
as for the tranny swap, the fact you already have a 2.8 makes it much easier. its still not a simple bolt on, assuming you mean an 01e (b5 s4) transmission. they do make an 01a 6 speed (same style as our trannies) which are basically bolt ons
Old May 29, 2013 | 09:09 AM
ImTheDevil's Avatar
I'll throw a quick nugget in here - for one, 2.7T is a twin turbo. 2.7TT (if that were an actual Audi engine designation) would be that same engine. And if you want affordable, you can forget the VRT setup.
Old May 30, 2013 | 05:02 PM
So I think I've decided to do the s4 conversion and go with a 2.7t + 6 spd trans. This is a parts list I've started. Anything else missing?
Ecu
2.7 block + heads + wiring harness
6 spd Trans
Intake and exhaust man
2 k03 turbos + intercooler+ diverted valves
Maf
Exedy clutch
2002SpeedyA4
Mar 25, 2014 12:54 AM
o0hmikee
Oct 24, 2011 10:19 PM
leang's2.8
Feb 11, 2011 07:34 PM
ckappler
Sep 27, 2006 04:48 PM
jadento
Sep 11, 2005 01:29 AM
