Bad fuel leak!
Old Apr 17, 2009 | 09:32 AM
preemo_28's Avatar
Default Bad fuel leak!
hello everyone, i have a bad fuel leak under the back side of my 97 audi a4 1.8 turbo quattro. it only leaks out when the car is running. i know where it's leaking from, but i don't know what the part is called. i placed a couple pics up here to see if anyone on here knows what it is. i appreciate the help.
Attached Thumbnails Bad fuel leak!-picture-322.jpg   Bad fuel leak!-picture-327.jpg
Old Apr 17, 2009 | 10:22 AM
gaberossi's Avatar
fuel filter/ pump probably if its near the tank in the rear of the car...just replaced mine took about an hour an 10 min
Old Apr 17, 2009 | 10:25 AM
ghost6303's Avatar
well its a good time to change your fuel filter anyway. just make sure you pick up 4 new cruch washers (2 for each side) with the filter and it wont leak.
Old Apr 17, 2009 | 10:36 AM
gaberossi's Avatar
u will be on your way grasshopper haha just messin around..good **** that u found out what it is.
Old Apr 17, 2009 | 11:44 AM
preemo_28's Avatar
thx . another thing..is the job a do-it-yourselfer, or should i leave it up to the mechanics?
Old Apr 17, 2009 | 02:15 PM
gaberossi's Avatar
If you have a working brain that makes good decisions then you should be fine....ill see if i can post a DIY on here but in the meantime look for one=)
Old Apr 18, 2009 | 12:29 AM
zadeluca's Avatar
i just had the same problem and replaced the filter and washers. here is the diy:
http://www.audiworld.com/tech/eng49.shtml
good luck!
natemoses13
Audi Q7
Sep 25, 2016 10:42 AM
JoshuaMixon
Oct 6, 2013 07:32 PM
lukestaah
Jan 15, 2013 12:26 PM
ow-de
Dec 5, 2011 11:03 AM
preemo_28
Apr 17, 2009 09:30 AM
