Bad misfiring in my 2.8
Old Dec 19, 2008 | 08:12 PM
generik777's Avatar
Default Bad misfiring in my 2.8
Well a couple months back my car started missing real bad, mainly in cylinder 4. I replaced the spark plugs,the spark plug wires, and the Ignition Coil Pack. None of those fixed my problem so I got frustrated and brought it to the mechanic.
The mechanic first suggested the intake gasket, But he replaced that and it wasn't the problem. So he tried swapping injectors, swapping spark plugs and plug wires, pressure tested the cylinders and all that. Nothing fixed the problem or moved the problem from cylinder 4 and the pressure tests came back perfect. He ordered a scanner from Audi that should be here sometime so he can do more detective work.
What could it be? BTW car is a 2.8
Old Dec 20, 2008 | 01:45 PM
generik777's Avatar
speed bump
Old Dec 20, 2008 | 02:17 PM
ST1FFY's Avatar
Member
did you find out what the problem was?
Old Dec 20, 2008 | 03:48 PM
generik777's Avatar
Nope. Still waiting.
Old Dec 24, 2008 | 02:52 PM
generik777's Avatar
no-one?
Old Dec 24, 2008 | 03:16 PM
ghost6303's Avatar
we are waiting for you to get around to asking the car whats wrong with it. you know it can tell you if you just ask. (scan the codes)
Old Dec 25, 2008 | 11:20 AM
generik777's Avatar
Yeah I've done that. It throws a code for misfire cylinder 4. It was throwing random cylinder misfire before also but hasn't done so yet since working on it. Now it just throws the cylinder 4 code.
cncbamf
May 9, 2017 05:39 PM
googlegot
Jun 10, 2012 06:25 PM
tketke
Nov 4, 2008 12:01 PM
limptimtim
Mar 16, 2007 11:21 PM
nitro_rider2001
Feb 27, 2007 07:39 PM
