battery run down, dead
Old 05-02-2010, 11:04 PM
alaska5beras's Avatar
Default battery run down, dead
2001 Audi A4 Q. Good battery, good alternator but intermittently battery found dead. No lights or radio on. When charger placed on battery fan noise is heard even before the key is turned on. The fan noise is from the passenger side of the car just behind the fog lights. It appears to be a black canister type item. Could this be the culprit. Don't, this is a care without a book and I am new at this. Thanks for any ideas
Bill
photo of what i feel is the problem
https://www.audiforums.com/forum/pic...856283&thumb=1
Old 05-02-2010, 11:23 PM
turbo kraut's Avatar
Tech Guru
you are talking about your secondary air pump.... unless there is short or constant voltage going to it, then i doubt that is it...
alot of times what i do if i can't figure stuff out is pay someone to track down the problem, then i fix it
Old 05-03-2010, 09:44 AM
When I disconnected it, the charging of the battery went normally. Can the car be driven without this pump for any period of time or distance?
Old 05-03-2010, 06:17 PM
02A6Beau's Avatar
You will throw a code a some point (probably)
The pump is an emissions control, nice to have but not necessary for normal driving operation.
(unless I'm wrong)
Old 05-03-2010, 09:32 PM
Tech Guru
you will throw a code, it is an emissions control device
unless you get your ecu recoded for it
Old 05-03-2010, 11:55 PM
srlito's Avatar
I wish i would have known i could have done that. I put a few resistors and a couple other electrical components in there to make the ECU think that its still there.
Old 05-04-2010, 12:06 AM
hiwords's Avatar
yeah you'll get a check engine light but the car should be fine without it. it doesn't cost much to get a used one though. the electric pump usually goes bad but the wiring rarely does.
Old 06-01-2010, 01:01 PM
mercap's Avatar
Default Secondary Air Pump. Me too. How to disconnect?
I posted a thread about this over the weekend. And I saw this thread while my car is being looked at by the Audi dealer service people. I have a 2003 A4. The fan turns off and on every 5-10 minutes and drains the battery. It sounds like disconnecting this will at least get me around till I can get the air pump replaced. How do I disconnect it, and is it easy to do?
thorjov
11-04-2015 09:19 PM
tom.beckman
09-02-2013 10:19 AM
Quick Reply: battery run down, dead
