BatWagon took a dump
Old 07-30-2012, 11:35 AM
FASTER's Avatar
Tech Slut
Default BatWagon took a dump
Here's the carnage of running a bad tune with a badass setup. Just a reminder to always be patient when doing a build.
Old 07-30-2012, 12:53 PM
CCA4's Avatar
Like I said on FB, I've never seen a piston split in half like that. Wild...
Saw you put it in storage, what's the plan? I assume you'll not be using another CTapp tune...? 034 standalone?
Old 07-30-2012, 01:11 PM
redline380's Avatar
Legal Moderator
that is pretty terrible. i havent seen many broken vag blocks, but that is by far the worst. do you know what caused it?
Old 07-30-2012, 01:36 PM
FASTER's Avatar
Tech Slut
I actually rented a garage where i can work on it. Its not much, but its enough. You are correct about an SEM, either 034 IIc or a Motec unit. Can't wait to ditch the HUGE maf and all the other b.s. along with it.
Yes, it has a smaller hole on the driver side as well but it was hard to get a good pic. I was as happy as could be when I lifted that head off and there was no damage to the top end.
As for the cause, I was trying desperately for the past few months to get the tune squared away, but the truth of the matter is that an 058 computer just cant run a setup like mine, plain and simple. It appears that the injector on cylinder 2 loaded up and dumped fuel, causing the cylinder to hydrolock and snapped a FORGED rod lol.
Old 07-30-2012, 02:18 PM
Sheasta's Avatar
Damnnn. That **** got destroyed! Poor piston got his tip chopped off his shaft. Poor block got penetrated. Complete rape.
Old 07-30-2012, 03:19 PM
bradtyler02's Avatar
Damn... damaged so bad the head flew off relocated to the "trunk."
Exactly where Chris likes to keep his stuff too!
Old 07-30-2012, 03:49 PM
FASTER's Avatar
Tech Slut
Yea but Chris has all the right junk in his trunk!
Old 07-30-2012, 03:52 PM
redline380's Avatar
Legal Moderator
perhaps 06a block and wideband conversion are in your future? ive heard the swap is tough but worth it in the end. makes me glad i got an 01 and i had no idea when i bought mine. i can tell you maestro for me7 is pretty ****, and theres a lot of support out there
Old 07-30-2012, 06:46 PM
FASTER's Avatar
Tech Slut
Yes, I agree that the computers in the 06a cars are way ******* better. But I'm not going to spend all that time designing and swapping harnesses just for a stock audi computer from a newer year. Truth is it would take longer to wire my car up for the wideband 06a ecu than it would to wire up a standalone. 034 even sells a wiring harness for you to run their IIc unit, I'm not sure its worth $750 but some people are that lazy or lack know-how. Maestro does rock for the newer VAG cars. If I could go back in time I would have 100% gone for an 01 A4 and then just swapped in an aeb head just like mine
Old 07-30-2012, 10:04 PM
ImTheDevil's Avatar
Couldn't believe those pics the other day. I'm glad the damage was kept all at the lower end of the engine. Looking forward to its resurrection
Quick Reply: BatWagon took a dump
