belly pan details needed 2000 a4 b5
Old Jan 31, 2013 | 07:03 PM
hartsoe1's Avatar
Default belly pan details needed 2000 a4 b5
Jason, I need more details about the belly pan hardware from ECS. Your web site shows various speed nuts and various screws (I want the cheap ones). I need you to re-post this diagram and indicate which screw is which, and which speed nut is which. I'll need the bracket, so I've figured out that the mounting screws for it use the 'not speed nuts' and are fully threaded. Also, this diagram shows screw 4 and 4a. I'm going to only put three screws across the front and one each at the ends of the bracket to actually hold the pan. I'll try to use my existing bumper speed nuts in place, but I assume I'll need two speed nuts for the new bracket ends. by the way, I found this diagram at the Zine.
Old Feb 3, 2013 | 11:49 PM
hartsoe1's Avatar
bump so Jason at ECS will see on Monday morning.
sempaipaul
Jan 20, 2008 11:36 AM
WItC
Oct 14, 2007 02:51 PM
