? Better ways to gap a spark plug ?
Old Apr 17, 2008 | 09:06 PM
oettinger1919's Avatar
SoCal Crew Member
Default ? Better ways to gap a spark plug ?
After replacing my plugs i found that gapping them with the classic little puck tool was not very accurate especially since were talking down to the tenth decimal place. Is there either a better tool out there or just a better method other than trying to line up the plug on the puck and jamming the metal arm down into it...
Old Apr 17, 2008 | 11:11 PM
feerocknok's Avatar
Default RE: ? Better ways to gap a spark plug ?
Get one of these gappers:
Far more accurate, and no chance to mess up.
Old Apr 18, 2008 | 12:43 AM
SoCal Crew Member
what do you actually bend the metal arm on though?
Old Apr 18, 2008 | 12:51 AM
feerocknok's Avatar
You bend the groud like you open a bottle on the side tab. That's the only real way to do it that I've seen, and I've seen some ways.
Old Apr 18, 2008 | 07:51 AM
chaos92287's Avatar
the little disc is very accurate if you know how to use it right, or get f6dtc's and not worry about gapping at all
Old Apr 18, 2008 | 06:13 PM
EOD5's Avatar
off topic but, the F6DTCs , are they stock temp... if so , what are the non-gappable equivalent t a cooler plug like the NGK BRK7E's?
is there an F7DTC?
Old Apr 18, 2008 | 07:24 PM
cincyTT's Avatar
I'm make believe
7's are colder than 6's.
Old Apr 18, 2008 | 08:52 PM
chaos92287's Avatar
ORIGINAL: EOD5
is there an F7DTC?
doesn't seem to matter with this plug. f6dtc's work in everything from stock a4's to Mike's 600+whp a4 to 034's vr6-t swap (running 40 psi)
Old Apr 18, 2008 | 09:02 PM
mattsaudi90's Avatar
There are gapping pliers as well. The picture shown, that tools works good. I simply use the old school disc, and it works well. Even if you are off a .01, it wont matter. (I dont see how you could, it is literly idiot proof.... I thought)
Pilipenko
Nov 28, 2011 10:06 AM
ee99ee
Oct 12, 2011 12:28 PM
Rmonster
Nov 9, 2008 02:03 PM
Audi_Skydiver
Sep 29, 2007 02:40 PM
