blew the exhaust pipe off my turbo
Old Jan 5, 2009 | 01:46 AM
superdooperme's Avatar
Default blew the exhaust pipe off my turbo
so, i was foolin around today and i gunned it and i redlined the car and i head a loud bang and then it sounded like i had no exhaust. so i got out, popped the hood, and my turbo was glowing bright orange, haha. anywho, after it cooled down i saw that the exhaust pipe right in front of the catalytic converter popped out from right behind the turbo and the 3 bolts.
so basically, i wanted to know what damage could i do if i continued to drive it like this. im planning on sliding it back in as best i can tomorrow.
i tried searching to see if this happened to others but i came up short. is this common? should i tack weld it back on or can i just use a u bolt?
ill try to get pics up tomorrow as soon as its light
Old Jan 5, 2009 | 06:07 AM
AudiCoupeV6's Avatar
Member
Sorry to hear, but it's not uncommon. Happend to me some time ago.
It's quite simpel to fix tough just remove the downpipe and the flange and weld them back together from the outside (originally welded from the inside).
Good luck!
Old Jan 5, 2009 | 07:25 AM
RyanSweeney's Avatar
Happened to me about two months ago. I ended up replacing the stock cat with a high flow cat from LaBree Motorsports.
Here's a write-up. http://www.audiworld.com/tech/eng114.shtml
Old Jan 5, 2009 | 08:49 AM
Sidewayzracer's Avatar
same here mines still broken
im gonna replace it with a test pipe and reweld the original and keep it round for the emissions
Old Jan 5, 2009 | 12:08 PM
Mike-2ptzero's Avatar
Plenty of people have had this happen to them, the weld on the stock cat just tends to crack over time because of the high EGT's and high back pressure in that area.
Search on Audizine and you will find plenty of threads.
Old Jan 5, 2009 | 01:44 PM
awesome, thanks guys.
i just about peed my pants when i hear it shoot off, haha.
i was driftin around in the rain and just foolin around cause i had just fixed a boost leak so i was all pumped cause my car felt better than new, haha.
Old Jan 5, 2009 | 06:30 PM
so, im tryin to slide it back in but i dont have much movement, any ideas? are there any bolts i should undue that will give me more movement?
Old Jan 5, 2009 | 09:27 PM
There's a hanger type deal under the car right by the flex pipe. You'll probably have to unbolt that thing to get the cat into position.
Old Jan 5, 2009 | 09:43 PM
even if u fit it back in itll just fall out again in time needs to be rewelded
gonna take it to a exhaust shop i know have him quote me on a reweld this week
ryanylva
Aug 14, 2009 03:57 AM
Audacity
Jun 3, 2009 02:57 PM
ijrc
May 30, 2007 12:59 PM
xav6ier
Dec 20, 2006 01:55 AM
joekilla525
May 10, 2005 12:07 AM
