Bloody evil audi!!
Old Jan 29, 2012 | 12:56 PM
jcA4Quattro's Avatar
Default Bloody evil audi!!
Just venting,
So i went to look for my lighter that i lost in my back seat and noticed it was floating in 2" of water, WTF!!!! trunk is a bit damp on passenger side and everything in my back driver seat area is flooded........really!!! what next!!!
Thanks for listening
Old Jan 29, 2012 | 02:25 PM
ImTheDevil's Avatar
Sunroof drain issue. Search it out - there's a lot of info on this forum including info on warranty repair of damages caused by this.
Old Jan 29, 2012 | 06:10 PM
murdox's Avatar
Pretty sure another guy made a post on this a few days back. You and him should talk about what you ,did to fix it. I'm sure there is commons
Old Jan 29, 2012 | 06:12 PM
murdox's Avatar
Pretty sure another guy made a post on this a few days back. You and him should talk about what you ,did to fix it. I'm sure there is common ground between the two of you.
You can try using a compressor and blowtip to flush the drains... But someone said it can potentially cause damage. I did this to my 98 b5. It didn't cause any damage really but it didn't fix the problem.
Gl
Old Jan 29, 2012 | 08:01 PM
M5S5's Avatar
Tech Certified
Another common problem is the drain under the battery tray. The drain will get full of leaves & debris , clog up & cause the a mini swimming pool in the cowling area & make it's way inside the car.
Something you have to remember is that the carpet has a 2" foam pad attached to it so the amount of water that you see is much greater then appears.
It would be most advisable to remove the seats , carpet & get things dried up as soon as possible. Another thing to keep in mind is that there are usually control modules of some sort housed under the carpets.
Water & control modules = No Bueno
Old Jan 29, 2012 | 11:08 PM
airguard350's Avatar
Tech Guru
Actually, about a year after I got my A4 (2009) I got a letter about a class action suit regarding the sunroof drain issue and unresolved warranty issues from dealers. You have to clean them on a relatively regular basis, though I lucked out and never had a problem.
Steven Glassey
Jun 21, 2012 05:05 AM
martydoyle
Dec 10, 2007 10:48 PM
ckandes1
Jul 9, 2006 12:50 AM
rnbguy
Mar 14, 2006 02:25 PM
