blowing fuses
Old Nov 14, 2011 | 06:04 PM
euroimport88's Avatar
Default blowing fuses
i just got my new head lights today. i get it all hooked up with the ddm 35w 5k bulbs, and then as soon as i turn them on i blow both headlight fuses. i triple checked my wiring its fine. i just keep blowing fuses. if i disconect on side the fuse wont blow and it will run the one just fine, then as soon as i hook both up it blows. i need help bad its to dark in the moring to not have working headlights
Old Nov 14, 2011 | 07:25 PM
raudi28's Avatar
put a bigger fuse in... the headlights obviously need more power just dont over do it. do your research and find out how many amps the headlights should run at, and use a fuse just higher than that
Old Nov 14, 2011 | 09:53 PM
MetalMan's Avatar
Are you using a relay harness or are you going straight through the stock wiring?
michaelm
Feb 20, 2011 03:11 PM
dbtt2001
Mar 1, 2008 07:29 PM
apr_a4
Dec 14, 2007 01:02 PM
GoodLuckAudi
Dec 12, 2006 06:00 AM
audi901990
Dec 28, 2004 09:37 PM
