Boost Loss / Turbo Flutter
Old Jul 9, 2012 | 08:36 PM
  #21
Tremar's Avatar
Also, I don't have a 5 bar FPR.. So maybe that's why it has some issues when the PSI gets up there, not enough fuel?
OH, and I had the green spring in my DV, would a stiffer one help?
Old Jul 9, 2012 | 09:10 PM
  #22
BaseDrifter's Avatar
Site Moderator/B5 Tech Guru
Be very very careful. If you don't have an adequate fuel supply for 25psi you run the risk of detonation and expensive engine woes if you're running lean.
I can't think of another reason that you would have turbo flutter (compressor surge) without it being related to the DV somehow. Did you install any shims inside the DV when you installed it?
Have you pulled codes since the flutter started? There might be a code there relating to the surging. (I had this issue myself and it was due to the vacuum line to the DV being blocked by a shim in the DV.)
I would recommend getting the N75 routed and connected properly and ensuring the DV is working properly.
Old Jul 10, 2012 | 07:30 AM
  #23
Tremar's Avatar
What exactly do you mean by "shims"?
And these are the codes I am getting, same as before
VCDS-Lite Version: Release 1.1
Tuesday, 10 July 2012, 06:45:05.
Control Module Part Number: 4B0 906 018 P
Component and/or Version: 1.8L R4/5VT G06 0006
Software Coding: 07201
Work Shop Code: WSC 06335
VCID: 2E2F8DBBF919
4 Faults Found:
17526 - Oxygen (Lambda) Sensor Heating; B1 S2: Open Circuit
P1118 - 35-00 - -
17522 - Shareware Version. To Decode all DTCs
P1114 - 35-00 - Please Register/Activate
16795 - Shareware Version. To Decode all DTCs
P0411 - 35-00 - Please Register/Activate
16524 - Oxygen (Lambda) Sensor B1 S2: No Activity
P0140 - 35-00 - -
Old Jul 10, 2012 | 04:06 PM
  #24
CCA4's Avatar
Adjustable, rebuildable DV's like the Forge 007 and 008 come with springs and shims to fine tune them. Allows you to make the springs effectively stiffer without jumping all the way up to a spring that may be TOO stiff for your application.
Old Jul 10, 2012 | 04:32 PM
  #25
Tremar's Avatar
Oh, yea I don't think I have any of those spacer things in there. I am going to take it out to put a stiffer spring in later today, since I fixed the boost issue. I will check for any disturbances in the vacuum hookup.
I am going to take it off, regrease it with some better grease (Mobil 1 Synthetic) and try putting it in reverse of what I had it before (Apparently this matters on Mitsubishi Evos.. Worth a shot).. See what happens.
Old Jul 11, 2012 | 03:27 AM
  #26
kraylon's Avatar
on my 01 when I would run my forge 007 in reverse (long side in intercooler piping) it would flutter, also if you are interested I have a forge Unos mbc I dont need any more that ill sell u, shoot me a pm if your interested.
Old Jul 11, 2012 | 09:51 AM
  #27
Tremar's Avatar
I am pretty sure that's how I have mine hooked up right now, going to change it around tonight (hopefully).
And I JUST ordered a Hallman MBC 2 hours ago. Shoulda checked the post first >_<.
Thanks for the offer though!
pablomigraine
Mar 23, 2015 10:20 AM
incadave
Sep 4, 2013 11:41 AM
CMoriart
Mar 22, 2011 09:05 PM
Cyclocross
Dec 14, 2008 04:37 PM
beatmstrj
Oct 6, 2006 08:39 PM
