BOV/DV Question
Old Aug 29, 2009 | 01:31 AM
Buckwheatjones's Avatar
Default BOV/DV Question
Ok, so if I get my A4 GIAC chipped do I need to replace my stock dv? And how does a BOV work with the recirculated A4? Thanks for any help.
Old Aug 29, 2009 | 05:08 AM
kriptonik's Avatar
Yes, you will need it replaced since the stock DV won't be able to hold the boost.
DV's are best for our cars. However, Forge came out with a splitter in which you can recirculate and release the air into the atmosphere at the same time if you want the BOV sound.
Old Aug 29, 2009 | 03:10 PM
Alright. So would this work : http://www.rallitek.com/gfbstfxbloff.html
Old Aug 29, 2009 | 03:37 PM
kriptonik's Avatar
What kind of BOV should I get?
Due to the closed loop turbo system in our A4's you can not release the air into the atmosphere, you have to recirculate it back into the system. The MAF calculates air before the DV so if any air is lost after that calculation by releasing it into the atmosphere you will run rich for a little while. How damaging this is, is disputable, but on 2000+ models the car adapts to running a BOV because of the MAP sensor so you will only run rich for a day or 2. The BOV will need to stay closed at idle. A BOV that remains open at idle is not good for a car with a MAF and you will stutter and stall. Forge 004 and SSQV are both closed at idle and good choices. If you run standalone software (034 Motorsports carries it) you can run any BOV you want.
There are also hybrid BOV's that only vent a portion of the air. The most popular are the Forge Splitter, and GFB. The splitter is the easiest to install and run and the GFB is just a little tougher, but you can adjust the amount released to atmosphere for 10-50%. The GFB is ~$250 and the Forge is $175 and can only release 10% vta or full dv (should only be left as both since it releases more air).
And if you have a B6, they are equipped with a Wideband o2, stock. the ECU is programmed from the factory with the target AFR, and it will adjust fuel trims accordingly to maintain that, tuned or untuned. So you can remove your MAF and run any BOV you want. Won't work with b5's.
If you have a pre-00 A4 can you run a BOV? Technically no, but I run one on my 98.5 with no problems whatsoever. You only run slightly rich right after you "blow-off" and I can't see it doing any damage. Maybe a catalytic converter in the long run, but I doubt it.
**note: I take no responsibility if you put a BOV on your car and it fvcks it up.
All taken from the Newbie Guide. It should have all the infos you need.
https://www.audiforums.com/forum/audi-a4-8/newbie-guide-version-2-a-80968/
EvoTillIDie1
Mar 5, 2014 10:42 PM
manindra
Feb 10, 2009 05:59 PM
SouthernAudi
Oct 14, 2007 06:47 PM
viper771
Mar 7, 2006 05:52 AM
