Brake Calipers hitting front rims need help!
Old Mar 22, 2009 | 06:18 PM
reservoirdog6991's Avatar
Default Brake Calipers hitting front rims need help!
I have a problem on my 97 A4 we can't figure out. During tight turns at slow speeds the brake calipers in the front are touching the rims, causing the front wheels to jerk back the opposite direction making a really loud banging noise. We replaced the control arms and half shafts but its still happening and are out of ideas. The rims are stock and we do have snow tires on but can't figure out why its doing that. The problem did seem to get worse and worse with time. Any ideas???
Old Mar 22, 2009 | 11:07 PM
kriptonik's Avatar
What kind of brake do you have?
Old Mar 22, 2009 | 11:20 PM
Default Brakes
I have the stock brakes that came on the car, thats the thing everything is stock and the rims are the original rims and about a month ago the problem started and just kept getting worse to the point its at now. We replaced the front rotors and brake pads awhile back but the problem didnt start until long after that. It only happens at low speeds and tight turns and you can see the wheels getting forced back. I did replace two of the snow tires with two of the exact same snow if that could have anything to do with it.
Old Mar 22, 2009 | 11:28 PM
kriptonik's Avatar
Post this under the B5 section for better response.
Old Mar 22, 2009 | 11:30 PM
kriptonik's Avatar
reservoirdog6991
Mar 23, 2009 07:56 PM
Rocket
Aug 7, 2008 10:40 PM
dafrazi
Jun 2, 2007 01:43 AM
shockedimpy
Jan 6, 2007 04:30 PM
dan23
Nov 13, 2006 05:59 PM
