brake fluid choice
Old Sep 15, 2009 | 06:12 PM
Tweaked's Avatar
Originally Posted by ghost6303
the ATE super blue fluid isnt DOT approved if that matters to you (because it has coloring additives). i dont know why any DMV inspection would ever look at your brake fluid color, but some autocross clubs forbid the use of it.
I believe that's due to it's low wet boiling point. Super Blue and DOT5.1 bothe require frequent bleeding or flushing to keep the moisture out and the boiling temp up.
Old Sep 16, 2009 | 12:01 AM
dragonrage's Avatar
ATE says every 2 years and I'd tend to believe that.
Old Sep 16, 2009 | 12:05 AM
exequiel3k's Avatar
I have a really stupid question for all;
how do I know when I have to add brake liquid fluid? I tried looking under the hood and it's impossible to see its current level.
Old Sep 16, 2009 | 01:36 AM
Tweaked's Avatar
The simple answer: When it's low.
The real answer: you should never have to top it up. Technically if it's low, it's an indication your brake pads are worn and need replacement or you have a leak. You should only have to open the reservoir to bleed or flush the brakes.
If the fluid is very low, it's going somewhere. It's either in the calipers (worn pads) or is leaking from a seal somewhere (master cylinder, caliper pistons, or obvious line leaks). Brake fluid does not evaporate or burn off if the braking system is functioning properly.
Old Sep 16, 2009 | 02:10 AM
Midniteoyl's Avatar
How can you not see the level? Dirt? If the tank is clean and you cannot see the level, pull the cap.
Old Sep 16, 2009 | 03:18 AM
Jc61990's Avatar
i ordered the DOT 4 fluid off JH Motorsports its supposed to be an OE replacement
http://www.jhmotorsports.com/shop/ca...roducts_id=435
Old Oct 3, 2009 | 11:25 PM
lleroyb's Avatar
Member
I use the ATE Super Blue or Super Gold in several cars and have had no squeeking or ill effects of any kind.
Lou
californiadaddy
Oct 24, 2013 01:06 AM
B5 Audi
Nov 27, 2009 05:24 PM
AR15Texan
Jun 10, 2009 12:24 PM
ttoo cool
Mar 25, 2007 11:40 PM
