Brake help
Old Jul 4, 2009 | 08:09 PM
CBenRieder600's Avatar
Default Brake help
So I am replacing my pad & rotors in the rear, and I have the caliper mounting bolts off but the caliper will not let the rotor go. The rotor turns in between the pads but I cant pull the rotor out. Now idk if I need to bleed the caliper to release some pressure or what but any help would be great. I should also mention that I loosened the two 13mm bolts on the top and bottom of the caliper thinking that it might release the rotor, maybe that was a bad move idk. Thanks
Old Jul 4, 2009 | 09:41 PM
2fast4u66's Avatar
http://www.audiworld.com/tech/wheel25.shtml that should help. Maybe try a large screw driver to aid the caliper off...
Old Jul 4, 2009 | 10:14 PM
hiwords's Avatar
you have to take the caliper carrier off too. it's the part that the caliper bolts onto
Old Jul 5, 2009 | 07:16 AM
99A4NOW's Avatar
I read the write-up but didn't notice anything about the rear caliper haveing to be turned while pushing the piston in... that is correct isn't it? I think if you try just pushing them straight in it may damage the caliper. Would someone correct me if I'm wrong?
Old Jul 5, 2009 | 08:42 AM
ImTheDevil's Avatar
That is correct. The front pistons just compress straight in. The rears require a screw-in brake kit. See the two notches on the face of the rear caliper piston, 180 degrees apart? Those are the turning notches. You use a screw-in kit to thread the pistons back into the calipers. The kit can be borrowed at AutoZone or Advance Auto.
Old Jul 5, 2009 | 03:57 PM
okay wow, good to know I figured out what I was doing wrong. Stupid mistake. But yeah I could not get the piston back into the caliper. I tried with a C clap so I hope i didnt do any damage. I will go pick up the kit and try screwing it back in. THANK YOU SO MUCH!!!
Old Jul 5, 2009 | 04:01 PM
2fast4u66's Avatar
http://www.audiworld.com/tech/wheel2.shtml
look at the bottom of the article to see a pic of the tool.
abc27
Aug 25, 2013 04:19 PM
NorthernComfort
Sep 19, 2007 07:54 AM
