break lights??
I put a LED strip pointing down on the rear bumper so it would illuminate when the break is pressed.....
... and i wired it directly to the bulb harness circuit thingy.....
....the LED illuminates when the break is pressed only when all the headlights are off...is there a different way to wire it so it will light up when the break is pressed and the headlights are on?
thnks
....the LED illuminates when the break is pressed only when all the headlights are off...is there a different way to wire it so it will light up when the break is pressed and the headlights are on?thnks
